ducatipaso.org • View topic - 906 Mikuni conversion filters
It is currently Fri Nov 14, 2025 6:26 am
 Post subject: 906 Mikuni conversion filters
PostPosted: Thu Jan 17, 2008 3:03 pm
Hi everyone and Happy 2008!
I recently installed a set of 900ss mikunis on my 90 906 paso. I had to construct an air filter set up using 2 K&N air filters. It works, but its probably the most hideous thing you'll ever see!
My question for you is what filters have everyone else been using with success? I have no factory air box to work with, so thats not an option. Ideas anyone? Thanks for your advice in advance and ride safe!
 Post subject: Re: 906 Mikuni conversion filters
PostPosted: Fri Jan 18, 2008 7:41 am
I converted jst some mothes ago my 750 Paso to Mikunis with Dynojet kit stage 1. and i used quite similar bomull pod filters, as K & N are, but they were some much cheaper model mande in far east, anyway liiks same, as much expensive. Price was 14€ / 2 filters. I havent driven my bike yet, but seems, that it runs well outside garrage. Test drive shall happen next April, or may.... :smoke:
PostPosted: Tue Mar 04, 2008 3:58 pm
PostPosted: Tue Mar 04, 2008 5:22 pm
Bob,
here some pictures of my Mikuni TDMR carbs and a friend`s ex-906 with Keihin carbs. Also with original Mikunis the position in the frame is the same.
You will find more info in the P750 FAQs.
