| Paso cam timing http://ducatipaso.org/forum/viewtopic.php?f=2&t=2303 |
| Author: | JWilliam [ Sat Feb 23, 2008 11:28 am ] |
| Post subject: | Paso cam timing |
Given that the 906 Paso has a cam timing that is quite 'soft', has anyone tried putting a set of 900ss cams to the 906 engine? They have the same lift for inlet and exhaust but longer duration. |
| Author: | Tamburinifan [ Sat Feb 23, 2008 12:40 pm ] |
| Post subject: | Re: Paso cam timing |
States here http://www.moto-one.com.au/performance/duccamspec.html that same cams in SS, 906, 907. |
| Author: | JWilliam [ Tue Feb 26, 2008 5:20 pm ] |
Nope, as per my 906 instruction manual the 906 has an inlet/ exhaust timing of : Inlet 20/60 Exhaust 58/20 (excluding Swiss model) But the spec for a 1997 900ss is inlet/ exhaust timing: Inlet 24/70 Exhaust 59/29 see the next link (Andres Ducati 900ss homepage) http://mysite.mweb.co.za/residents/an000003/ele2.jpg Furthermore there is an article within this very website from performance bikes that states the the 906 cam timing is the softest tune from Ducati yet (1989). http://ducatipaso.org/docs/906/articles ... -03-89.zip So according to my information it would appear that the 906 has a softer tune than a 900ss. |
| Author: | paso750 [ Tue Feb 26, 2008 7:50 pm ] |
Ducati belt-drive two-valve twins restoration and modification guide states: 906/907ie/900SS/E900/M900....................20°/60°...58°/20° 900SS (1994-1996).................................43°/85°...82°/46° 900 SS FE (1997-98)/M900S (1998-99)..........24°/70°...58°/29° 900SS (1998-)/M900 (2000)......................25°/75°...66°/28° so it depends on the year. G. |
| Author: | Tamburinifan [ Wed Feb 27, 2008 1:03 am ] |
| Author: | paso750 [ Wed Feb 27, 2008 9:35 am ] |
| Author: | Tamburinifan [ Wed Feb 27, 2008 9:44 am ] |
| Author: | JWilliam [ Wed Feb 27, 2008 1:15 pm ] |
Hmm, wonder which ones give the most power? |
| Author: | Tamburinifan [ Thu Feb 28, 2008 3:15 am ] |
On the 2V 900, alot seems dependant on manifold lenght: http://www.visi.com/~moperfserv/carbs.htm |
| Author: | jcslocum [ Wed Mar 05, 2008 10:54 pm ] |
ST2 cams are supposed to be the hot setup for the 900SS. |
| Author: | Finnpaso [ Thu Mar 06, 2008 8:58 am ] |
They are also very good choise to 907IE engine...
