| head steering bearing http://ducatipaso.org/forum/viewtopic.php?f=2&t=2325 |
| Author: | dennis916 [ Sat Mar 08, 2008 3:26 am ] |
| Post subject: | head steering bearing |
hi, does anybody know where can find the head steering bearing for 906 ? :thanks |
| Author: | paso750 [ Sat Mar 08, 2008 10:34 am ] |
| Post subject: | Re: head steering bearing |
from your Duc dealer no, honestly were are you located ?On the bottom right of the SKF homepage you`ll find a list of distributors selling to end customers: http://www.skf.com/portal/skf_us/home If you are in Europe and not knowing if the seller will ship outside Germany, this would be a good deal: http://cgi.ebay.com/2-x-Kugellager-Kege ... dZViewItem G. PS: a few days ago I made a summary of bearings in the P750 FAQ |
| Author: | JWilliam [ Sat Mar 08, 2008 1:45 pm ] |
| Post subject: | Bearing code |
The code for the steering head bearing is 32005X-90KA1. The cones will come out with a pin punch but you will need an angle grinder to cut off the bottom bearing. |
| Author: | paso750 [ Sat Mar 08, 2008 7:47 pm ] |
| Author: | jcslocum [ Sun Mar 09, 2008 4:36 pm ] |
The bottom race can be a PIA. If it's hard to remove then cutting a slot in it will make it slide right off. |
