ducatipaso.org :: View topic - Which wheels for upgrading
ducatipaso.org
http://ducatipaso.org/forum/
http://ducatipaso.org/forum/viewtopic.php?f=2&t=2730
Author:  higgy [ Mon Sep 15, 2008 11:09 pm ]
Post subject:  Which wheels for upgrading
In deference to the vast experience available here I have a simple question. Which later model wheels offer the easiest solution for the 16 inch tire dilemma?
Author:  Finnpaso [ Tue Sep 16, 2008 4:42 am ]
Post subject:  Re: Which wheels for upgrading
I think 907IE swingarm, wheels and brakes.... :smoke:
Author:  ducapaso [ Tue Sep 16, 2008 5:29 am ]
Author:  higgy [ Wed Sep 17, 2008 1:07 am ]
While this might be the simplest in terms of modifications required to accomplish,how hard is it to acquire wheels,brakes and a swing arm from a 907? I suspect it would be easier,for me anyway to add to my 906 swing arm than to find 907 parts at an affordable price. Also there a a lot of 900ss wheels to be had. I also suspect it will be easier to get michelin to make 16 inch tires than to find 907 parts. Are 907 parts truly a viable option these days?
Author:  Desmo_Demon [ Wed Sep 17, 2008 10:27 am ]
Author:  paso750 [ Wed Sep 17, 2008 5:08 pm ]
Author:  Desmo_Demon [ Wed Sep 17, 2008 11:53 pm ]
Author:  ved [ Sat Sep 20, 2008 11:31 pm ]
i did the conversion and use a 5,5" rim, 180 tyre with the original swingarm.
the rims of the newer ducatis are compatible (750, 900, st2), the difference is the design, bearing, spacer inside the rim and brakedisk.
i had to machine the left eccentric and move the chain outward (ca. 5mm) to get a clear alignment of the wheels.
if i do the coversion today, may i choose the 4,5" rim or at least 170 tyre. the clearence is really less.
but the 180 looks good :cool:
Author:  jcslocum [ Sun Sep 21, 2008 2:16 am ]
There is a thread in the 750FAQ about making the change.
Page 1 of 1 All times are UTC
http://www.phpbb.com/
