Repairing a Digiplex http://ducatipaso.org/forum/viewtopic.php?f=2&t=2813 |
Author: | Asterix [ Tue Oct 14, 2008 8:28 am ] |
Post subject: | Repairing a Digiplex |
Digiplex on my Paso 906 did not work correctly cause to intermittent problem on vertical cylinder ignition. ![]() Therefore, I have opened the box and I have detached all connections from circuit to the framebox. Inside it I found the circuit completely covered with a protective rubber plus 2 big transistors. I suppose the problem was one of final power transistors. I frozen over/around it with electronic circuit refrigerant gas and immediately the vertical cyl begin to run. Quickly, I run to buy two new transistors (BU931ZP – price € 4.50), replaced it but, with great disappointment, the vertical cyl did not work fine. ![]() Therefore, without fear, I began to remove delicately, with a toothpick, the rubber from the circuit. ![]() I found few electronics components under the rubber and many great lines from the transistors to external pin 10 11 12 (pin towards the coils). When I freeze one of this lines, vertical cyl begin to run. ![]() ![]() Sure and happy to have solved the problem, I have solder bridge from transistors (which one link to pin 11 - vertical cyl) to external pin and all it has worked. ![]() I Am much happy, Ciao a tutti P.S. in the afternoon I post same photos |
Author: | Tamburinifan [ Tue Oct 14, 2008 9:20 am ] |
Post subject: | Re: Repairing a Digiplex |
Well done, thx f sharing! Looking forward to pics. |
Author: | Asterix [ Tue Oct 14, 2008 6:55 pm ] |
Author: | jcslocum [ Tue Oct 14, 2008 11:39 pm ] |
This shows the lenghts folks will go to keep their Pasos running. Help and electrical fool understand something. Why does freezing the circuit make it work?? |
Author: | Asterix [ Wed Oct 15, 2008 8:56 am ] |
Author: | Tamburinifan [ Wed Oct 15, 2008 9:59 am ] |
![]() Do you have a wiring schematics of the Digiplex as well? |
Author: | Asterix [ Wed Oct 15, 2008 12:58 pm ] |
Author: | Tamburinifan [ Wed Oct 15, 2008 5:24 pm ] |
So how did you know to make additional wire in pic 2? |
Author: | Asterix [ Wed Oct 15, 2008 6:57 pm ] |
Author: | Asterix [ Wed Oct 15, 2008 8:43 pm ] |
Sorry, this is a complete Digiplex pic (by internet) Transistor are under vacuum device. transistor location, green line are the original bridge to carry hi current original bridge |
Author: | Tamburinifan [ Thu Oct 16, 2008 12:00 am ] |
Thx again! We can probably run our Paso`s forever when guys like you chime in... ![]() Do you work w electronics f a living? |
Author: | persempre907 [ Thu Oct 16, 2008 6:34 am ] |
So, if it only was a circuit fault, it could be quite easily redone for a perfect recover... Great job! Ciao |
