ducatipaso.org • View topic - Mikuni Carbs vs manifold vacuum to Digiplex
It is currently Sun Sep 28, 2025 2:00 pm
 Post subject: Mikuni Carbs vs manifold vacuum to Digiplex
PostPosted: Tue Jun 09, 2009 12:33 pm
Hi all,
First a thanks to everyone for the help this board has already given me in deciding to buy a Paso. There really is a wealth of information here.
My question comes from the fact I have a bunch of leftover 600SS spares from another rebuild/project bike that I'd like to use on the 906 - especially the Mikuni carbs and 17inch wheels :)
But........when fitting the Mikuni carbs from a supersport, how should the intake mainfold vacuum input to the digiplex be dealt with?
If removing the Paso airbox and using pod filters can the vacuum take-off points on one of the supersport intake manifolds be used? (i.e. the holes normally blocked by a screw or used for carb sync)
Or
Should you try and retain the paso airbox connected to the mikuni's? Is that possible?
Or maybe I have got it wrong and there is no problem??
Mick
 Post subject: Re: Mikuni Carbs vs manifold vacuum to Digiplex
PostPosted: Thu Jun 11, 2009 12:32 pm
It is better with pictures I think.
What to do with the line from the digiplex (red arrow on Paso parts diagram) when installing Mikuni carbs?
I think it is OK to plug the hoses on the paso parts diagram (blue arrows) to the manifold holes on the 900SS parts diagram (also blue arrow).
Or am I making this all up in my head? Is is really required? Has anyone needed to do this?
cheers,
Mick
PostPosted: Thu Jun 11, 2009 10:57 pm
Just connect it to the manifold as you have it circled. You might want to run it to both manifolds so you get a smoothed out vacuum.
PostPosted: Sat Jun 13, 2009 5:47 pm
Thanks mate - good point on linking to both manifolds.
Will use the existing plumbing on the Paso to try and match the minimum inner bore / restriction for the sensor.
Mick
906 Paso 1989 w/ 17in wheels :)
