| clutch pressure plate http://ducatipaso.org/forum/viewtopic.php?f=2&t=3081 |
| Author: | Mc tool [ Mon Feb 23, 2009 11:56 pm ] |
| Post subject: | clutch pressure plate |
been thinkin about making a new pressure plate for the old slapper. Im quite happy to leave the piston in the clutch cover ,but I would like to fit the berring onto the pressure plate and make a piston with a spigot that fits into the berring. Mine has been munted by the previous owner Any one done anything similar ..... or totally different that works |
| Author: | duckboy [ Tue Feb 24, 2009 11:43 am ] |
| Post subject: | Re: clutch pressure plate |
I do recall seeing a setup using a "thrust needle roller bearing", although it was a long time ago, and in the pits at a race meeting. if you have access to a lathe, it would not be too hard to turn up some spacers to adapt to this type of bearing, although the slave piston may need some machine work as well. |
| Author: | Mc tool [ Tue Feb 24, 2009 8:50 pm ] |
I was thinking more of a axial load ball berring , similar to the one in my 97 SS . And yeah I do have a lathe , so I can spin up a pressure plate and a new piston with no berring . The only issue is getting it all under the cover coz there aint a whole lot of room there |
