Hit a bump, Engine Cuts, Backfire, then fine http://ducatipaso.org/forum/viewtopic.php?f=2&t=3535 |
Author: | micklm [ Tue Jul 28, 2009 11:49 am ] |
Post subject: | Hit a bump, Engine Cuts, Backfire, then fine |
Hi all, Problem is sorted but thought it might give some folks a laugh. Had the 906 for a few months now and it runs pretty well. Then suddenly everytime I hit a decent sized bump in the road, the engine cut out, then backfires and then is fine. Having been through a lot of the excellent reference material here before I bought the bike, I started having nightmares about electrics and float settings and various other carb problems (I have an active imagination). Started looking at the simple things first and for once it was a simple thing. The positive terminal screw on the battery had worked its way loose over time. When I hit a bump it must have broken the ignition circuit momentarily, putting unburnt fuel into the exhaust for the next cycle! Boom. Maybe I do have an underlying electrical problem to find (knock on wood), but for now, tightening up the battery terminal has completely solved the problem. Tools away, carry on riding. cheers, Mick |
Author: | Finnpaso [ Sun Aug 02, 2009 5:07 pm ] |
Post subject: | Re: Hit a bump, Engine Cuts, Backfire, then fine |
Mostly of those backfiring problems are coming from that Weber carburator, so You have to tune it first... When i had Weber in my 750 paso, it "backfired" quite often, then i changed to Dellortos, not anymore .... and later to Mikunis, not anymore backfing... ![]() |
Author: | higgy [ Sun Aug 02, 2009 8:27 pm ] |
backfiring with the weber if it is the cause and not some intermittant electrical issue can be resolved by raising your idle jets a size or two to richin up the mixture(more fuel,less air) |
Author: | micklm [ Tue Aug 04, 2009 11:15 am ] |
Hi all, For now it seems to be solved and I'm not keen to touch the weber while it it working well! Definately was only backfiring whenever I hit a bump and no other times. And hasn't happened again since....fingers crossed! cheers, Mick |
Author: | timmetje [ Mon Aug 10, 2009 3:38 am ] |
hi mick, i had the same a while ago, only when i hit a bump, turned out to me a loose connection at the battary. no big deal. |
Author: | jomo [ Mon Sep 07, 2009 2:03 pm ] |
Mick, keep looking for that loose battery terminal or similar. Carbys are not sensitive to bumps. Last time I had that problem was the battery terminal and it killed my clock. |
