Output shaft end play http://ducatipaso.org/forum/viewtopic.php?f=2&t=3574 |
Author: | Duc906 [ Wed Aug 26, 2009 11:53 am ] |
Post subject: | Output shaft end play |
G'day all I was checking the front sprocket today and I noticed some end play in the shaft.Could somebody tell me how much end play,if any, is allowable please. |
Author: | higgy [ Thu Aug 27, 2009 12:09 am ] |
Post subject: | Re: Output shaft end play |
I believe it should be 0 to .2mm for both of the gearbox shafts |
Author: | Duc906 [ Thu Aug 27, 2009 9:43 am ] |
Thanks Higgy Hmmm,I have 1.2mm.Any thoughts on a cause or remedy.All my thoughts end up with me pulling the motor out and splitting the cases,yikes. ![]() |
Author: | jomo [ Thu Aug 27, 2009 11:42 am ] |
When you say end play, do you mean the amount of play with the bike in gear, on the centre stand and you rotate the rear wheel forward and backward to observe the freeplay? Because that worries me on my 906. |
Author: | higgy [ Thu Aug 27, 2009 8:36 pm ] |
the movement of the shaft in and out of the case, I would not be concerned about your most likely gear backlash...There probably is a spec for it but I have no idea what it would be ![]() Measured at the tire it would be several iinches.........at the gears themselves several tenths of an inch Duc906 Does the bike shift OK? Is the up and down motion(run out) of the shaft nice and tight? How many miles? I plan to be doing some work to my 906 this weekend, so I'll see what I have and get back to you, The spec I suppose could be a misprint...........I also have an engine apart and I'll look it over to see what might be done to remedy the situation |
Author: | Duc906 [ Fri Aug 28, 2009 11:45 am ] |
Author: | Duc906 [ Thu Oct 01, 2009 11:19 am ] |
This has finally got the better of me,so I stripped the engine down this week to find out what is wrong. Turns out there is a shim washer missing from between the shoulder on the shaft and the bearing,"A". That was allowing the 2nd gear to rub on the bearing retainer,"B",fortunately it has not warn it greatly. According to the 906 parts catalogue the part number is 067016171.Does anybody know weather these are still available,if not,has someone got a spare they don't need. |
