Soul of the Paso http://ducatipaso.org/forum/viewtopic.php?f=2&t=3837 |
Author: | higgy [ Thu Jan 07, 2010 1:27 am ] |
Post subject: | Soul of the Paso |
teaser teaser teaser ![]() ![]() ![]() The Soul Of The Paso belongs to the Weber ![]() The soul of the Weber is the ET and AV ![]() stay tuned...............for one more chapter in Weberolgy 101 ![]() |
Author: | Finnpaso [ Thu Jan 07, 2010 12:50 pm ] |
Post subject: | Re: Soul of the Paso |
ET??? AV??? |
Author: | paso750 [ Thu Jan 07, 2010 2:11 pm ] |
emulsion tube and auxiliary venturi |
Author: | Finnpaso [ Thu Jan 07, 2010 6:22 pm ] |
Thanks, "G" ![]() |
Author: | higgy [ Fri Jan 08, 2010 12:36 am ] |
we have details on a modified stock f27 emulsion tube in conjunction with 4.5 auxiliary venturi's and a few other standard mods to solve all those weber blues out in Pasoland. Warwick and I are working on the final draft and it should get posted very soon. As a side note it most likely will work with the stock 3.5 aux venturi's just not as well..... Hey Antti, or G any chance you guys have a data sheet on a motorola MC68705S3CS ![]() |
Author: | Finnpaso [ Fri Jan 08, 2010 4:49 am ] |
I am very hurry just now(no time to look closer), but try this one: http://www.ic2ic.com/search.jsp?sSearchWord=MC68705S3CS |
Author: | higgy [ Fri Jan 08, 2010 7:01 am ] |
already checked every resource I could find and posted a request on at least 5 different electronics forums including one for motorola So far no luck and I don't know enough about it to know the difference between an s3cs or an r3cs or a p3cs. I can get one for either the r or p '3cs' but have not come up with an s3cs. I suppose I could get either of the r or p or both and map them out and then map out the s and look at the differences between the 3 and decode it that way. Any of your input would be appreciated on the idea ![]() ![]() ![]() ![]() Thanks Antti ![]() ![]() |
Author: | Mc tool [ Sat Jan 23, 2010 4:24 am ] |
