| Seat Fix http://ducatipaso.org/forum/viewtopic.php?f=2&t=3846 |
| Author: | Duc906 [ Sat Jan 09, 2010 6:27 am ] |
| Post subject: | Seat Fix |
For those that are having trouble with their seat moving forward and releasing from the latch at the back while they are riding,I have a fix.All I did was to cut a piece of fuel hose down the side and slip it over the back of the fuel tank mount,add a bit of silicon to keep it in place,simple.If one piece is not enough just add another over the top. |
| Author: | Mc tool [ Sat Jan 23, 2010 4:16 am ] |
| Post subject: | Re: Seat Fix |
Now thats the sort of repair I like to see, cheap , effective and not unsightly. Pity you didnt use #8 wire to hold it on but there you go . .If the rest of that bike is as clean and tidy as the bits I can see it will be a nice bike regards hamish |
| Author: | duckboy [ Tue Mar 02, 2010 4:23 am ] |
Hiya Ken this incident first happened to me, whilst on a ride... a long way from home. unfortunately when the seat swung off, the rubber bumps under the seat tore the wires out of the battery, and killed all electrics. (so there was a bodgey roadside repair to the wiring, and half a roll of duct tape used to secure the seat.) annywaay... here is how I solved the problem. It looks a bit rough, but it does the job. cheers Brett |
| Author: | persempre907 [ Tue Mar 02, 2010 7:33 am ] |
| Author: | Duc906 [ Tue Mar 02, 2010 8:02 am ] |
Hey Duckboy Good to here from you. Hopefully your rear end was still not in the seat when it hit the ground. Your fix is a bit less agricultural than mine,good work. |
| Author: | duckboy [ Tue Mar 02, 2010 9:59 am ] |
Luckily the seat never actually hit the ground, I was able to trap it between my leg, and the sidecover as it was half hanging off. It happended after a large bump in the road which lifted me out of the seat (actually the seat came with me), I think it snapped the wires (to the battery) as I was trying to re-position it without stopping. Brett |
| Author: | hardo [ Fri Sep 28, 2012 5:58 pm ] |
Dear all I have the same problem and just the fix provided by duc 906. It helped for quite a while but the problem is here again. The fixing at the end of the seat (rear end of the the paso) pops of. Any suggestions for a quick fix? Thank you, Hardo |
| Author: | stigonpaso [ Fri Sep 28, 2012 11:50 pm ] |
I'm planing to go the Duckboy route by putting a thicker plate on the end of the seat. |
| Author: | Mc tool [ Sat Sep 29, 2012 12:23 am ] |
| Author: | JWilliam [ Sun Sep 30, 2012 9:17 pm ] |
Not heard of this one. I got around this by using a Diopa single seat unit for the last few years apparently. It must be the plastic under tray deforming... tricky. |
| Author: | lane1feathers [ Thu Feb 21, 2013 12:23 am ] |
I used the now obsolete muffler retaining bolt, drilled out the hole a bit, and glued it in with some REAL GOOD glue. (Obsolete as I have after market mufflers) Works real good This is more of a trial to see if I can successfully upload a pic to my thread, so bear with me! |
| Author: | lane1feathers [ Thu Feb 21, 2013 12:24 am ] |
....damn.....
| Author: | paso750 [ Thu Feb 21, 2013 9:01 am ] |
fixed |
| Author: | lane1feathers [ Thu Feb 21, 2013 11:40 am ] |
Awesome, it worked Now I can put it up here instead of just a link Thanks G. PS feel free to delete these last messages |
