ducatipaso.org • View topic - Radiator Mount cracked
It is currently Tue Sep 30, 2025 4:10 am
 Post subject: Radiator Mount cracked
PostPosted: Mon Mar 22, 2010 8:11 am
While refitting the right side fairing I noticed a crack in the bracket between the radiator mount and the frame:
It is an aluminium bracket but welded nicely with the Tig.
I suggest you have a look at your radiator mounts next time you remove your fairings, or if you are paranoid the brackets are visible with just the scoop covers removed. Here it is repaired, repainted and refitted:
Cheers, CB
Ducati 906 Paso
Kawasaki GPZ900R
Triumph Sprint 955
 Post subject: Re: Radiator Mount cracked
PostPosted: Tue Mar 23, 2010 8:24 am
Now I have refitted the fairings, I realise both sides are visble through the vents without removing the covers :thumbup:
CB
Ducati 906 Paso
Kawasaki GPZ900R
Triumph Sprint 955
PostPosted: Wed Mar 24, 2010 2:00 am
You bet'ca. Have done both of mine. Built it up a little thicker at the inside of the bend before grinding it down.
du907
Users browsing this forum: No registered users and 39 guests
