It is currently Fri Nov 14, 2025 6:26 pm
 Post subject: Fitting mikuni carbs
PostPosted: Sun Sep 19, 2010 9:13 am
Hello,
I have a paso 906 1991. My weber carb is broken, and i bought a set of 2 mikuni carbs from a monster 900. I realized that i need also new collectors, do you know if the ones from M900 are ok for the paso?
I'm also planning to remove the airbox and use cone filters instead.
Do you know if does it exist some sort of guide on how to fit this carbs (also a carb reference manual is good enough :) )? I remember some web pages with lot of guides but i can't find them anymore...
Any suggestion is welcome!
thanks again!
Davide
 Post subject: Re: Fitting mikuni carbs
PostPosted: Sun Sep 19, 2010 9:25 am
Try here;
viewtopic.php?f=1&t=705&start=15
Or if that doesn't help, try the search function :beer:
