| belt tensioners and idle pulleys anybody? http://ducatipaso.org/forum/viewtopic.php?f=2&t=4368 |
| Author: | nnnnnnorman [ Thu Oct 14, 2010 7:48 pm ] |
| Post subject: | belt tensioners and idle pulleys anybody? |
ive been told it would be a good idea to change my belt tensioners and idle pulleys while im at my engine overhaul. has any body got any they want to sell or can recomend a supplier? its a 906. thanks.
| Author: | ducapaso [ Thu Oct 14, 2010 8:07 pm ] |
| Post subject: | Re: belt tensioners and idle pulleys anybody? |
Why not original spare parts? belt tensioner are standard bearings available anywhere, idle pulleys should be worth for less tham 100~120 usd |
| Author: | nnnnnnorman [ Thu Oct 14, 2010 8:26 pm ] |
thanks nicola its an option worth considering if no one has any laying around gathering dust and lookin for a new home. |
| Author: | Mc tool [ Thu Oct 14, 2010 10:24 pm ] |
I thought about replaceing those too but the idler on mine the mounting bolt and the roller were one part assy and bloody expensive ....... so they are still there
| Author: | giocast [ Fri Oct 15, 2010 10:16 am ] |
Just as McTool says, the one-piece bearing (SKF as std) is expensive as it's probably peculiar to our 2v engines (around £35 from Ducati) but the other side-by-side bearing (i.e. 2 required per belt) can be obtained anywhere (as ducapaso has said) for less than at Ducati dealers. The company 'simply bearings' has a good reputation and I would certainly recommend that you try them. |
| Author: | nnnnnnorman [ Fri Oct 15, 2010 2:45 pm ] |
thanks giocast all usefull information there.
