lower bolt on the rear shock? http://ducatipaso.org/forum/viewtopic.php?f=2&t=4410 |
Author: | nnnnnnorman [ Tue Nov 02, 2010 8:05 pm ] |
Post subject: | lower bolt on the rear shock? |
im having a nightmare removing the lower bolt from my 906 rear shock. nut was well tight but despite soaking for three days in fluid the bolt will not budge in any direction at all. it is solid! any suggestions? thanks ![]() ![]() ![]() |
Author: | higgy [ Tue Nov 02, 2010 10:20 pm ] |
Post subject: | Re: Rear spring |
the careful application of heat,preferably from a heat gun/hair dryer alternatively propane...keep it away from all things flammable like fuel and battery drain tubes,anything rubber,plastic et.c |
Author: | paso750 [ Tue Nov 02, 2010 10:40 pm ] |
Post subject: | Re: lower bolt on the rear shock? |
that and a torque wrench for a longer lever should do the job. G. |
Author: | nnnnnnorman [ Tue Nov 02, 2010 10:54 pm ] |
thanks guys will try tomoro night. the swing arm is off the bike so nothing flamable is nearby but awkward to get a grip on! help is arriving tomoro evening ![]() ![]() ![]() |
Author: | streetsurfer [ Wed Nov 03, 2010 2:31 pm ] |
Have you tried an impact wrench or impact driver on it? The hammering movement of an impact wrench usually helps where brute force fails. |
Author: | Mc tool [ Wed Nov 03, 2010 9:07 pm ] |
Hi Nnnnnnorman , If you can turn that bolt but its still stuck its probly rotating the lower eye bush in the shock , if you cant turn it its probly stuck in the ally casting , which is better , but either way I would try to remove the shock and the bottom link together and move it all to the work bench,. Once you have figured where it seized ( bottom eye or the casting ) and have properly supported the bit you will probly have to drive it out with a hammer and punch, a press would be better but...... . If its anything like my swingarm pivot bolt ![]() ![]() ![]() the 4 bushes in the little pic that I have arrowed are the most likley , especially the inner bush for the 2 needle berrings on the left side , to sieze onto the pivot shaft. If they do seize you will see that the pivot shaft will rotate freely with any bush its siezed to , so turning it wont help . I wound up lying the bike on its left side , with the frame around the swing arm pivot supported , and bashed it out with a log splitter. good luck Nnnnnorman ![]() |
Author: | nnnnnnorman [ Wed Nov 03, 2010 10:42 pm ] |
yes. success. after a bit of heat a lot of spray and plenty of club hammer the lower shock bolt is out. it took a long breaker bar to get it moving in the alloy sleaves and a good thumping from the hammer to free it from the central 'collet'? it was corroded into. copper slip for re assembly. now all i have to do is rebuild the unit before it goes back in. thanks for the advice guys. ![]() ![]() ![]() |
Author: | higgy [ Wed Nov 03, 2010 10:48 pm ] |
Author: | nnnnnnorman [ Wed Nov 03, 2010 11:16 pm ] |
thanks. on closer inspection the top eye of the shock is cracking. should i weld or replace this part or start looking for a new unit alltogether? ![]() |
Author: | higgy [ Thu Nov 04, 2010 12:24 am ] |
welding is workable,need a decent welder ![]() |
