Clutch renewal http://ducatipaso.org/forum/viewtopic.php?f=2&t=4518 |
Author: | Bainesy [ Thu Dec 30, 2010 7:55 pm ] |
Post subject: | Clutch renewal |
I am gradually sorting out problems with my 906..I have had 17" wheels put on without any issues and the electrical problem I had (engine missing when indicators turned on, or off, brake applied etc) has been fixed with a relay to the ignition -or somewhere... a friend fixed this for me.. Next problem - the clutch was making metallic grinding noises when taking off in first gear..moves through the gears OK and idles OK - the usual rattling noise in neutral. I have pulled out the clutch discs and while they don't look too bad - although I have never looked at clutch discs before - maybe they are worn??!! I plan to replace them, and the springs. I can't seem to easily find replacements for them, although I think I have found a place in Queensland which might have something. There might also be a basket there - I will call them and see what they offer. I thought I should also replace the pressure plate as well, while I was there, but I am not sure where/how to find one of these. Any advice welcome Regards PS The ride I had after the electrical problem was fixed made me think this is a fantastic bike to ride! |
Author: | nnnnnnorman [ Thu Dec 30, 2010 8:01 pm ] |
Post subject: | Re: Clutch renewal |
thats right. there is nothing like a 906 when its pumping properly. good luck and enjoy! and happy new year! ![]() ![]() ![]() |
Author: | jcslocum [ Thu Dec 30, 2010 9:30 pm ] |
The metallic noises might be clutch "groan" when pulling out from a stop. This is a normal condition happens on many Ducs with the dry clutch. It's usually caused by dust in the clutch cover. If you are referring to the "jangle" noise that sounds like a handful of nails in a coffee can, then get used to it. That's the sound a dry clutch Duc makes. Enjoy it!!! |
Author: | higgy [ Thu Dec 30, 2010 11:41 pm ] |
Author: | Bainesy [ Fri Dec 31, 2010 4:17 am ] |
The "jangle" noise is only there when in neutral and doesn't worry me at all. The "groaning" noise worries me and only seems to be present when I take off from a standstill - and is much worse if greater strain on the take off -ie if starting up a hill. It seemed to get worse the longer it was being ridden, but again only noticeable when taking off in first gear. I have measured the friction plates and really only one of them was less than the suggested 0.11 inch. I still plan to replace them... I have purchased a socket to take off the nut holding the clutch drum in place - I need to work out a device to hold the clutch while I undo the nut...or I might just try replacing the discs and see how it goes... Again, any advice welcome Tahnks for the responses. Best wishes for the New Year Regards |
Author: | paso750 [ Fri Dec 31, 2010 11:34 am ] |
Author: | jcslocum [ Sun Jan 02, 2011 3:08 am ] |
You don't need to pull the basket to replace the clutch. If the basket is boogered up or has ridges in the basket fingers, they can be cleaned up with a file/grinder. |
Author: | Mobius [ Sun Jan 02, 2011 8:33 am ] |
Author: | Bainesy [ Sun Jan 09, 2011 4:34 am ] |
Just to be complete: I replaced the discs with a new set; left the basket/housing and didn't touch this, although I have ordered a tool to hold the clutch just in case I need to play with it again later... The clutch now works fantastically!!! No noise on take off, a little "jangle" only with the clutch in...the sound of the bike on the open road is magic!! Just have to wait for the next problem to arise ![]() Thanks for all the advice Regards |
Author: | romus [ Sun Feb 13, 2011 3:25 am ] |
Author: | higgy [ Sun Feb 13, 2011 4:23 am ] |
This guy stocks the Barnett aluminium discs down your way brad@bikeboy.org 2B King Street, Oakleigh Victoria 3166 |
Author: | persempre907 [ Tue Feb 15, 2011 5:29 pm ] |
But, fitting the aluminium discs, there is the need of an aluminium basket to avoid bad wear of the clutch. Ciao |
Author: | Mc tool [ Wed Feb 16, 2011 6:38 am ] |
Hi Bainsey , i gotta be in wellington next week ( dunno why I think your in welly ) but if you want I'll bring you my clutch tool as I can easily make another , and if your not in welly I could just courier it ![]() |
