ducatipaso.org • View topic - Clutch renewal
It is currently Mon Sep 29, 2025 1:15 am
 Post subject: Clutch renewal
PostPosted: Thu Dec 30, 2010 7:55 pm
I am gradually sorting out problems with my 906..I have had 17" wheels put on without any issues and the electrical problem I had (engine missing when indicators turned on, or off, brake applied etc) has been fixed with a relay to the ignition -or somewhere... a friend fixed this for me..
Next problem - the clutch was making metallic grinding noises when taking off in first gear..moves through the gears OK and idles OK - the usual rattling noise in neutral.
I have pulled out the clutch discs and while they don't look too bad - although I have never looked at clutch discs before - maybe they are worn??!! I plan to replace them, and the springs. I can't seem to easily find replacements for them, although I think I have found a place in Queensland which might have something. There might also be a basket there - I will call them and see what they offer. I thought I should also replace the pressure plate as well, while I was there, but I am not sure where/how to find one of these.
Any advice welcome
Regards
PS The ride I had after the electrical problem was fixed made me think this is a fantastic bike to ride!
 Post subject: Re: Clutch renewal
PostPosted: Thu Dec 30, 2010 8:01 pm
thats right. there is nothing like a 906 when its pumping properly. good luck and enjoy! and happy new year! :thumbup: :cool: :)
1990 906 paso red and white
1991 906 paso black and gold
1997 ST2 red
1962 rover 95 p4
1997 iveco daily
PostPosted: Thu Dec 30, 2010 9:30 pm
The metallic noises might be clutch "groan" when pulling out from a stop. This is a normal condition happens on many Ducs with the dry clutch. It's usually caused by dust in the clutch cover. If you are referring to the "jangle" noise that sounds like a handful of nails in a coffee can, then get used to it. That's the sound a dry clutch Duc makes. Enjoy it!!!
PostPosted: Thu Dec 30, 2010 11:41 pm
PostPosted: Fri Dec 31, 2010 4:17 am
The "jangle" noise is only there when in neutral and doesn't worry me at all. The "groaning" noise worries me and only seems to be present when I take off from a standstill - and is much worse if greater strain on the take off -ie if starting up a hill. It seemed to get worse the longer it was being ridden, but again only noticeable when taking off in first gear.
I have measured the friction plates and really only one of them was less than the suggested 0.11 inch. I still plan to replace them...
I have purchased a socket to take off the nut holding the clutch drum in place - I need to work out a device to hold the clutch while I undo the nut...or I might just try replacing the discs and see how it goes...
Again, any advice welcome
Tahnks for the responses.
Best wishes for the New Year
Regards
PostPosted: Fri Dec 31, 2010 11:34 am
PostPosted: Sun Jan 02, 2011 3:08 am
You don't need to pull the basket to replace the clutch. If the basket is boogered up or has ridges in the basket fingers, they can be cleaned up with a file/grinder.
PostPosted: Sun Jan 02, 2011 8:33 am
PostPosted: Sun Jan 09, 2011 4:34 am
Just to be complete:
I replaced the discs with a new set; left the basket/housing and didn't touch this, although I have ordered a tool to hold the clutch just in case I need to play with it again later...
The clutch now works fantastically!!! No noise on take off, a little "jangle" only with the clutch in...the sound of the bike on the open road is magic!! Just have to wait for the next problem to arise :)
Thanks for all the advice
Regards
PostPosted: Sun Feb 13, 2011 3:25 am
PostPosted: Sun Feb 13, 2011 4:23 am
This guy stocks the Barnett aluminium discs down your way
brad@bikeboy.org
2B King Street, Oakleigh
Victoria 3166
PostPosted: Tue Feb 15, 2011 5:29 pm
But, fitting the aluminium discs, there is the need of an aluminium basket to avoid bad wear of the clutch.
PostPosted: Wed Feb 16, 2011 6:38 am
Hi Bainsey , i gotta be in wellington next week ( dunno why I think your in welly ) but if you want I'll bring you my clutch tool as I can easily make another , and if your not in welly I could just courier it :)
