| Rear Sprocket bolts all sheared off http://ducatipaso.org/forum/viewtopic.php?f=2&t=4580 |
Page 1 of 4 |
| Author: | Mobius [ Fri Feb 04, 2011 7:40 pm ] |
| Post subject: | Rear Sprocket bolts all sheared off |
New Thread for this subject. As I said in the other thread, after about 100km of open road riding, never above 6000 rpm and always below 120km/h, I lost all drive after a non-powered gear change from 4th to 5th, in an 80km/h zone. I had stopped at Taitapu 15km beforehand and visually inspected the rear sprocket and chain as I have had some of these bolts loosen before. Now, the bolts I used were high-tensile, and I also used some "very special" anti-undo washers: two part things with a rachet surface against the sprocket, and each part of the washer has zig-zag surfaces whose angles are greater than the angle of the thread. The idea is that any force applied to them can't undo the bolt because it pulls up harder against the thread than the torque applied to it. The sales person was very specific, he told me not to over-torque the things ("AS YOU'LL NEVER GET THEM UNDONE!"). Well, I now have the bike at home, but haven't removed the sheared off ends yet. They all snapped in exactly the same place by the look of it, but I have not yet diagnosed whether they really have undone and smashed off on the swingarm, or if the whole lot let go at once. Once I get them out, I'll be able to see where on the bolts the break happened, and hopefully I can then use that to establish what mode of failure hit me. Thanks for the posts about the lock-tite and the wired-up-bolts idea - I like both of those. I think I like the wiring idea better, as it means you don't have to check the bolts themselves, as a visual clue is given by the wires. I think this is the approach I'll take. But I wonder, why on earth does this keep happening? I had four separate instances prior to replacing the bolts and washers where the bolts would undo! I thought the new combination had sorted it - but apparently not. I have never heard of any such behaviour on any bike, and certainly I never EVER had to tighten sprocket bolts on any previous bike. Is it something to do with the thumpy and lumpy nature of the twin-pot power delivery? I guess there must be huge pulses of torque travelling down the drive chain, and this must hit the sprocket like a sledge hammer. |
| Author: | paso750 [ Fri Feb 04, 2011 8:25 pm ] |
| Post subject: | Re: Rear Sprocket bolts all sheared off |
did this already happen with the original tires or only after putting on the 180/60? With the 180 did you offset the sprockets ? If so did you use longer bolts and is the rear sprocket still on the centering edge of the sprocket carrier and do the sprockets align correctly ? In what condition is the rubber damper below the sprocket carrier ? G. |
| Author: | Mobius [ Sat Feb 05, 2011 9:08 pm ] |
All excellent and relevant questions! I never did any miles on the original tyres, except to get them replaced. No, I did not offset the sprocket at all, but after I lost two of the original sprocket bolts due to loosening, I replaced them all. All the alignments seem correct. I now face the problem of undoing the large hex bolts inside the ex-center. I simply can't budge them to remove the wheel. Today I'm gonna get a pipe to go over the big hex key so I can get more leverage.(I wondered about the condition of the rubber damper also and that's why I want the wheel out.) Having removed all the bolts now, I can see they all snapped off right at the end of the thread, which is about 1mm below the head itself, so just the heads are missing. Photo below. The rachets of the washers I used have created clear markings on the sprocket itself and they are all perfect impressions. In other words, no signs of them having loosened. What I interpret this to mean is that the bolt heads were simply sheared off. In the position that they were in, they were done up all the way, and have NOT worked their way loose; they've simply snapped off. Above you can see the snapped-off bolts. The trailing edge of all the bolts (except one) have very wear on the threads (But not the leading edge which means they have not rotated in position). It's easy to work out why: there is nothing on the back (inboard) side the sprocket which keys into the driving plate it is bolted to. This means the bolts themselves provide the driving force to the rear wheel, and the only thing holding them in is the tension created by the thread. This seems to me to be the most stupid possible arrangement! What fool would create such a system? It seems patently obvious to me (and I'm not an an engineer) that the sprocket must have drive points which key into the drive plate, thus, the bolts would only be used to secure the sprocket to the plate, and the driving force would be applied directly to the wheel via the sprocket keys, rather than the bolts. Of course, now I'm wondering if this is how it is meant to be, and the sprocket I have is some after market thing not intended for use on the Paso. The sprocket is marked with the following: 238-5/8" I am certain that if I simply replace these bolts, the exact same thing will happen again, because they have not come undone at all. |
| Author: | higgy [ Sat Feb 05, 2011 9:50 pm ] |
Just a few observations Mobius,You got me wondering about mine From the looks of the bolts they appear worn by the sprocket suggesting some part of the assembly was overtightened or more likely stretched/worn to a point where the assembly could not provide the clamping force required to keep this sort of thing from happening. In my case it was only 2 bolts came out. One day they had been fine,the following day I went out for a quick ride to check on a mod I made,heard a squeek which by the time I noticed and stopped had become a thump thump thump. I now have some nice new scratches in my swing arm as two of the bolts did their level best to shorten the swingarm. Now to venture a guess, the most likely suspect is the rubber,at best it is 20 to 22 years old The number two suspect would be the metal used to capture the nuts that hold the whole thing together. assuming the bolts and nuts went together clean...no grit Hey we are talking about a Ducati Anyway, I plan to take mine apart over the next few weeks.I have been informed at work our dyne is to be commissioned within the next 9 weeks which gives me 8 weeks to get the 906 ready for the final phase of the Weber/exhaust work,considering the fact that I am currently inundated by snow and ice,indeed not a lot of time. I will however take some detailed pics so U and I can compare our findings And perhaps save a few Ducatista's a similar fate,sound like a plan?G, or any one else with considered experience please feel free to add your thoughts pro or con at anytime ![]() Looking at your pics again,what is on the bolts? is that rubber? If it is in fact rubber,heat should help you get it apart,if it is any other substance.Got PBX down under? |
| Author: | micklm [ Sat Feb 05, 2011 10:39 pm ] |
Mobius, If you have a good photo of the bolt end on, showing the cross section where it failed, it can be possible to say if the bolts failed in a brittle or ductile fashion. This can help identify the root cause. One thing I've had problems with before (not on bikes but in my work) with high tensile bolts is if they have been plated by someone and not baked after to remove the hydrogen charged into the steel by the plating process, this can make them brittle. Have the bolts been re-finished or are you aware of their origin? I agree though, that the damage to the threads around the failure area does point to the bolts backing out and the sprocket being a little loose for some time prior to failure - or was this damage done after the failures while trying to remove the bolts? Cheers, Mick |
| Author: | Mobius [ Sat Feb 05, 2011 10:46 pm ] |
Thanks for taking an interest Higgy. The stuff on the bolts is a little lithium grease, and nothing more. All the bolts went in clean and easy, and bolted down without a problem. They also undid easily when I removed them. (Question, what fool arranges loose nuts behind the drive-plate for the bolts to bolt up into? I had to use a strong magnet to pull two of them far enough outboard for the bolts to screw into!) The more I look at G's photo of his rear sprocket though, and the retaining bolts, the more I think I have the wrong combination of rear sprocket and retaining bolts. The bolts which have snapped are identical to the bolts I replaced them with. My rear sprocket has a totally different appearance to the one G displayed. Lemme get some photos real quick... Here's a hole in the sprocket. You can clearly see the marks left by the super-special-never-undo washers I used. No sign of it having come undone at all. The other holes are the same. Here's a bolt completely through the sprocket bolt hole. Note the non-snug fit here. The hole is about 1mm wider then the bolt. Here's the outboard face of my sprocket. It's marked 238-5/8" Here's the inner face of the sprocket. Clearly shown is the "lip" (about 2mm or so) on the inboard face of the sprocket. Also note the complete absence of any mechanism to transfer the power to the wheel, on the inner face. That can't be right - can it??? Any and all input greatly appreciated. |
| Author: | higgy [ Sat Feb 05, 2011 10:56 pm ] |
Lithium grease? Hmmm.maybe you did this to yourself.....Rubber parts generally can't handle petroleum or silicone grease of any kind (Although silicone grease is OK in some limited situations depending on the rubber composition) and should be assembled dry,the only acceptable lubricant would be water and even then only if it can evaporate in free air..............JM2C.....will still look into mine so we can compare ![]() BTW,the rubber is the intended transfer of torque part of the equation |
| Author: | Mobius [ Sat Feb 05, 2011 11:09 pm ] |
| Author: | Mobius [ Sat Feb 05, 2011 11:12 pm ] |
| Author: | Mobius [ Sat Feb 05, 2011 11:20 pm ] |
| Author: | paso750 [ Sat Feb 05, 2011 11:47 pm ] |
| Author: | higgy [ Sun Feb 06, 2011 1:33 am ] |
Mobius Just to clarify All the bolts do here or in the case G presented with a wheel, is provide the clamping force. They are in no way intended to be involved in torque transfer beyond clamping the parts, it is the friction between the material they clamp together that does the duty of torque transfer In this case even a small amount of lithium grease will allow the rubber to slip making the bolts do the job of torque transfer,something for which they are not designed to do The thing I find odd here is that they appeared to have sheared on the outside plane of the sprocket,On first impression I would have thought they would shear on the inside of the sprocket |
| Author: | Duc906 [ Sun Feb 06, 2011 1:41 am ] |
| Author: | Mobius [ Sun Feb 06, 2011 4:11 am ] |
OK, excellent contributions here, thanks very much people! Yes, I now understand that friction on the sprocket carrier created by the bolts is what is supposed to carry the force to the wheel. It still seems like a very poor design however. In my view the sprocket should have shaped lugs which insert into the sprocket carrier to transfer 100% of the load. In that scenario there would be zero deflection of the bolts and zero lateral force applied to the bolts. Yes the bolts sheared off at the outside edge of the sprocket, not the inside, which would seem more likely! Yes, my sprocket is reversed to gain the extra clearance for the chain. And because this would alter the chain offset I had a chat to a very experienced engineer friend of mine (who also happens to restore old motorcycles) before I initially did it. He says that 2mm over the reach of the Paso chain "is effectively straight". "Trust me", he said, "it will not be an issue, especially with modern chain technology." So, I without evidence to the contrary, I discount the 2mm offset as being anything to do with this issue. I did not replace the nuts inside the sprocket carrier when I replaced the bolts, I just assumed they would be fine. (They went in easily). Far more likely I think, is the sprocket carrier being somewhat damaged (slogged out holes) or the rubber part is minced, or the bolts supplied to me were not of the quality that I stipulated when I purchased them. I hope the later is the case. I will certainly use lock-tite next time, and the one G recommended in the other thread. |
| Author: | higgy [ Sun Feb 06, 2011 4:33 am ] |
| Page 1 of 4 | All times are UTC |
