Is this normal? http://ducatipaso.org/forum/viewtopic.php?f=2&t=4836 |
Author: | Giscard [ Mon May 30, 2011 6:48 am ] |
Post subject: | Is this normal? |
My familiarisation with my non-running Paso continues. As it had been idle for about 4 years I felt that putting some oil into the spark plug holes would be wise. Turning the engine over by hand using the rear wheel with the bike in gear reveals a noise like a ratchet from inside the alternator cover. Turning it over faster seems to eliminate this. I assume this must be related to the starter mechanism as I imagine the starter drive may be permanently engaged and not use a bendix type engagement. The starter does not work so I can not try this although I think the problem with that may be due to the solenoid, but that is another story. Is this noise normal or is it something else I may need to add to my list ? |
Author: | Giscard [ Thu Jun 02, 2011 9:55 pm ] |
Post subject: | Re: Is this normal? |
OK perhaps I did not explain very clearly what I was after with the original posting. Can anyone tell me exactly how the starter motor engages when the starter is activated and what it engages with. I have looked at the manual but it doesn't help me visualise it. Does anyone have a picture or can point me in the direction of a clear diagram so that I can decide whether it is something I need to dismantle. I keep reading about a sprag clutch but really do not have a clue as to what it is or how it functions. Thanks |
Author: | higgy [ Thu Jun 02, 2011 10:01 pm ] |
