| Alternator cover http://ducatipaso.org/forum/viewtopic.php?f=2&t=4865 |
| Author: | Giscard [ Thu Jun 09, 2011 7:42 pm ] |
| Post subject: | Alternator cover |
I am trying to get the alternator cover off with the engine in the frame so that I can replace a duff starter motor. The cover has moved by 2-3 centimetres with the aid of a puller but now seems jammed on the side stand anchor point. Am I missing something or do I have to take the engine out of the frame to get the cover off. Can it really be that difficult ? |
| Author: | paso750 [ Fri Jun 10, 2011 7:36 am ] |
| Post subject: | Re: Alternator cover |
remove the lower frame rail if the cover hits it. G. |
| Author: | Giscard [ Fri Jun 10, 2011 8:19 am ] |
Thanks. Clearly I was missing something. I am too used to old British bikes with one piece frames. I will remove the left hand cradle which looks like that should allow the cover to come off so that I can get at the starter motor bolts. |
