It is currently Wed Oct 01, 2025 2:19 am
 Post subject: I have a 1990 paso 906
PostPosted: Wed Sep 21, 2011 5:09 am
the problem im having is the speedometor is not working what can i look for? :banghead:
 Post subject: Re: I have a 1990 paso 906
PostPosted: Wed Sep 21, 2011 6:42 am
Hello And Welcome. Take the nose cone off (6 screews), unscrew cable where it goes in speedo. check inner cable turns when front wheel turns. Hopefully its the cable snapped or the drive broken. Either are cheap and easy to replace.
PostPosted: Wed Sep 21, 2011 9:19 am
ok thanks,ill try that :)
