| Venhill Install http://ducatipaso.org/forum/viewtopic.php?f=2&t=5163 |
| Author: | higgy [ Sat Nov 19, 2011 5:49 pm ] |
| Post subject: | Venhill Install |
The original The kit The install reused the brake switch and removed the caliper to hang it high to ease the bleeding hassle..........All fittings are torqued to 18ft-lbs(25Nm) Dot 4 fluid more to come......... |
| Author: | paso750 [ Sat Nov 19, 2011 6:07 pm ] |
| Post subject: | Re: Venhill Install |
I wonder why one end isn`t by 90° turned or can you do that ? If both are the same the line has to be warped which is not ideal. G. |
| Author: | higgy [ Sat Nov 19, 2011 6:14 pm ] |
you can turn them any way you like as they are a bolt on part Next pictures will get more detailed on the kit and the dimension Joking needs |
| Author: | JoKing [ Sat Nov 19, 2011 6:43 pm ] |
Cool! I am looking forward to that |
| Author: | ducinthebay [ Sat Nov 19, 2011 7:04 pm ] |
I too ordered a hose from Venhill. When I get it, I will also post pictures of the my install, but on the Sport page. I like the fact that you can rotate the fittings on the Venhill stuff. I have a box of hoses, but many I can't use because the heads are in the wrong orientation. Cheers, |
| Author: | higgy [ Sat Nov 19, 2011 7:35 pm ] |
Got a complete set,rear front and clutch I believe the clutch line is the same on the 906 and 907 |
| Author: | persempre907 [ Mon Nov 21, 2011 10:01 pm ] |
Are you sure? I guess the clutch line is too long for the 907. The 906 one has to come to the clutch cover. Ciao |
| Author: | higgy [ Tue Nov 22, 2011 10:13 am ] |
Length could be different but the fittings are the same, clutch line was a custom fit now that you mention it
| Author: | paso750 [ Tue Nov 22, 2011 11:14 am ] |
| Author: | higgy [ Thu Nov 24, 2011 6:57 pm ] |
The Venhill Clutch Line Custom Kit Thanks to Chris at Venhill USA The old line at the master The old line at the cover Cheapo bleed setup..5 dollar flavor injector of 1 ounce capacity, You could most likely find one for a dollar at your local dollar store Please note Jonboy Slocums coffee can/vacuum cleaner method works just as well.....Atta boy Jon Hope you are home with your family today Took very little to bleed it completely...3/4 of an ounce of air and two fills on the master and ready to go Well except my regulator jobs needs to be completed Up next the new front brake line setup and the pictures I forgot of the new clutch line fittings My apologies to Chris, so sorry and Happy Thanks Giving to all who celebrate this day ![]() The forgotten photos of the new clutch line |
| Author: | higgy [ Sat Dec 03, 2011 4:04 pm ] |
For the brake lines there are several options. I went for the two line direct eliminating the equilizer/brake pressure switch. This requires a new option for the brake light switch of which there are two. One is a two line banjo bolt with a pressure switch at the master or the one I most likely will do is to install the Brembo Microswitch on the lever ala the 907ie. I got both of these from Bevel Heaven The old lines removed: 21 years old well past time to go the new lines One comment in passing, the banjo bolt supplied with the brakeline kit was about 4mm too long. In the interest of time I ground it down, I have no doubt Chris would have happily swapped me with the correct bolt if I asked . ![]() I will also remove the calipers and hang them higher than the master to make bleeding easier
