Mechanic started bike in 1st while it was on side stand http://ducatipaso.org/forum/viewtopic.php?f=2&t=5292 |
Author: | eident [ Wed Mar 14, 2012 9:49 am ] |
Post subject: | Mechanic started bike in 1st while it was on side stand |
Was going over some work on my Paso. I told the mechanic that you had to be careful with this bike to make sure it's really in neutral when it says it is. He decided to show me some kind of "safety feature" as he put it in first before he turned it off (while it was on its sidestand). Then while standing next to the bike and without holding in the clutch all of a sudden he started it again before I could say more than "wait a second..". Luckily the choke wasn't engaged. Regardless my bike surged forward against the side stand and he had to grab the bike really quick. Apparently he decided to test whether my 1990 Paso 906 had a safety feature that prevents it from being started while in gear, or maybe while on its side stand. Obviously it has no such safety features. Do you guys know if this sort of thing tends to damage the bike or kickstand assembly? I mean it's a fairly big heavy bike and it kind of "hopped" up on the side when its weight surged against the lowered stand before it folded. Anyway I told them to be sure it's in NEUTRAL. Mostly all I know to be is irked right now.. will be a bit longer before I get it back and can check it out. Thanks |
Author: | randtcastell [ Wed Mar 14, 2012 4:31 pm ] |
Post subject: | Re: Mechanic started bike in 1st while it was on side stand |
That was extremely cavalier of the mechanic to do this contrary to your advice and more thorough understanding of the conditions. I would be very nervous about his competency. Any other options for you as far as mechanics go? Best of luck to you! |
Author: | Mc tool [ Thu Mar 15, 2012 8:03 am ] |
Author: | paso750 [ Thu Mar 15, 2012 8:30 am ] |
even if that action wasn`t so good for your starter motor it surely didn`t damage anything. You`re lucky the mechanic was so fast to catch the bike. Usually they then tip over and the search for a left mirror starts ![]() If I remember correctly the sidestand just cuts the ignition but indeed it wouldn`t be bad if it cut the starter instead. G. |
Author: | Duc906 [ Thu Mar 15, 2012 8:37 am ] |
Mate, if I was you I would be getting my bike back from this idiot before he does any serious damage. Apart from putting unnecessary stress on your starter sprag clutch I don't think he would have caused any other damage. It sounds like this guy needs a visit from the Ducati Mafia. ![]() ![]() ![]() |
Author: | eident [ Thu Mar 15, 2012 8:44 pm ] |
Thanks you guys. Yeah trust me it didn't go over well with me either. |
Author: | Mc tool [ Fri Mar 16, 2012 7:26 am ] |
Author: | paso750 [ Fri Mar 16, 2012 8:42 am ] |
you may be well right. It`s been a while since the last time I was in the garage ![]() |
Author: | persempre907 [ Fri Mar 16, 2012 5:52 pm ] |
I do confirm! When the side stand is open, only the lamp is on the dashboard. G., it's the time to ride your bike! Ciao |
Author: | higgy [ Fri Mar 16, 2012 6:01 pm ] |
even with the lamp I always look to be sure. stand down on any bike = not good things to follow ![]() ![]() |
Author: | paso750 [ Fri Mar 16, 2012 6:19 pm ] |
