| F C R's http://ducatipaso.org/forum/viewtopic.php?f=2&t=5307 |
| Author: | Mc tool [ Sat Mar 24, 2012 1:59 am ] |
| Post subject: | F C R's |
Does anyone out there know a bit about these beasts . I just scored a pair of 41's ( actually think Ive been ripped off ). They are split and there is only one accellerator pump ( on the front carb ) and a small hose linking it to the back carb , which sorta makes sense, just that all the pix I have seen show one pump per carb The other issue is that there seems to be a bit of wear in the throttle shaft/ carb body ... is there a replacable bush in there ? And where do you get o/haul kits (every time I look for any sort of FCR kit I get install kits inc carbs for various bikes ) I need float bowl seals acellerator pump seal and diaphram and the little piece of plastic that sits above the ball valve in the acc pump . These carbs were supposed to be newly overhauled before I got them , but plainly havn't and as Im sick and tired of being fucked about and lied to Ill just sort them myself . If any one can point me to a service manual or even a decent parts diagram I be grateful
| Author: | higgy [ Sat Mar 24, 2012 10:35 am ] |
| Post subject: | Re: F C R's |
Can't help you down under but herre are 2 just in case |
| Author: | Mc tool [ Sat Mar 24, 2012 10:41 pm ] |
Thanks Higgy . I had found both of those , not sure if it was before or after I posted. I spose I should give em a try before anything else, just gotta sort some filters . Thanks Higgy |
| Author: | paso750 [ Sun Mar 25, 2012 9:18 am ] |
You`ll find my collected info here http://www.box.com/s/329ay6zzob9yspyisl01 (the link was fixed) G. |
| Author: | Mc tool [ Mon Mar 26, 2012 1:51 am ] |
Yahooo! thanks G, this will keep me busy for a while . Bit of a story I bought them un seen ( and stupidly assumed they would be a joined pair like the mikuni's ) and was told by the seller that he would " re kit/overhaul them , I then waited 7 months for parts to turn up ( usual for him , just doesn't order/ forgets to order then blames suppliers ), finally went in and threw a wobbly and got the carbs , seperate , and obviously never been worked on , but by then I didnt care . And now , lookin at these things Im wondering just how practical they would be on a street bike and Im thinkin I'll just go with the original plan to fit the SS mikunis to the paso , just gotta sort some sort of air filter(s) for them. Thanks again for the info G , much appreciated Hamish |
| Author: | Desmo_Demon [ Mon Apr 23, 2012 3:54 pm ] |
| Author: | Mc tool [ Tue Apr 24, 2012 11:46 pm ] |
Thanks for that desmo demon , I have seen that site b4 but I lost it . I will give him a bell and see . Thanks |
| Author: | Desmo_Demon [ Wed Apr 25, 2012 1:43 am ] |
