| starting problems http://ducatipaso.org/forum/viewtopic.php?f=2&t=5390 |
| Author: | timmetje [ Sun May 20, 2012 7:21 pm ] |
| Post subject: | starting problems |
oi guys, long time no see, i'm having problems starting, did a overhaul at the startingengine, its not the problem now. it seems to be a problem with a sprocket behind the generator, anyone ever encountered a problem like this? |
| Author: | giocast [ Sun May 20, 2012 8:03 pm ] |
| Post subject: | Re: starting problems |
are you talking about the infamous starter sprag? - is the starter failing to turn over engine and making a noise you havent heard before? Unless it's been doing it for some time then you may be able to shorten the tensioner spring that runs around it's perifery. I will try and find a link to show the procedure unless someone else manages it sooner. Here you go :- http://www.mad-ducati.com/Technical/Sta ... lutch.html |
