| Timing shaft http://ducatipaso.org/forum/viewtopic.php?f=2&t=5504 |
| Author: | Duc906 [ Sat Aug 04, 2012 7:49 am ] |
| Post subject: | Timing shaft |
Does anyone know if a later model timing lay shaft will fit the 904 engine? I need to replace one and I have been offered a cheap shaft from a 749/999 but I'm not sure if it will fit. |
| Author: | Mc tool [ Sat Aug 04, 2012 8:05 am ] |
| Post subject: | Re: Timing shaft |
| Author: | Duc906 [ Sat Aug 04, 2012 9:30 am ] |
Thanks Mctool, you're vast knowledge and advice is, as always, very helpful.
| Author: | paso750 [ Sat Aug 04, 2012 10:51 am ] |
I don`t know either but the one of the 906/907ie is #14710011A which is the same on: 851/888/748/916. The later timing shaft is 14710141A and is used on: S4 2002 S4R 2004 - 2006 S4RS 2006 ST2 2000 - 2003 ST4 2000 - 2003 ST4S 2002 - 2005 ST4S ABS 2003 - 2005 ST3 2004 - 2005 ST3S ABS 2007 748 1999 - 2002 748S 2000 - 2002 748R 2000 - 2002 996 1999 - 2001 996S 1999 - 2001 996SPS 1999 - 2000 996R 2001 998 2002 998S Bostrom-Bayliss 2002 998R 2002 998 Matrix 2004 998S FE 2004 749 2003 - 2006 749S 2003 - 2006 749R 2004 - 2005 999 2003 - 2006 999S 2003 - 2006 999S AMA 2007 999R 2004 - 2005 As the 748 is listed for both my guess is the first is the one from 94-98. G. |
| Author: | Derek [ Sat Aug 04, 2012 11:05 am ] |
The models listed for the later shaft have a different crankcase with the 3-phase alternator. I would reckon it won't fit. |
| Author: | Duc906 [ Sun Aug 05, 2012 10:58 am ] |
Thanks G, Derek & McTool.
| Author: | Mc tool [ Wed Aug 08, 2012 11:16 pm ] |
When trying to find what part might fit whatever , Sometimes it worth a look on flea bay to see if anyone has listed one with pix , a quick look might be all you need to know if it will fit or not
