| rough running 906 http://ducatipaso.org/forum/viewtopic.php?f=2&t=5843 |
| Author: | dmartis [ Fri Feb 15, 2013 11:55 pm ] |
| Post subject: | rough running 906 |
Rough running 906. help my paso running rough. ok from cold seems to run fine, warms up after 10 min or so and has a major miss and runs eraticly and barely manages to keep going. if it stalls or is shut down it will not start until cold. does this sound like a coil or is there more to it. cheers guys
| Author: | persempre907 [ Sat Feb 16, 2013 7:08 am ] |
| Post subject: | Re: rough running 906 |
The same issue happened when I've got the 906. It was the flywheel pick up. Try to check it. However, it's a very common unit which was mounted on many FIAT group cars. Ciao |
| Author: | dmartis [ Sun Feb 17, 2013 12:43 am ] |
CHEERS MATE. GREAT ADVICE. I WILL CHECK IT OUT. SEEMS TO ALWAYS RUN SWEET FROM COLD. EVEN WITH NO CHOKE ETC. WAS THIS THE SAME AS YOURS. THANK YOU
| Author: | persempre907 [ Sun Feb 17, 2013 8:26 am ] |
Yes. No problem when cold. Steady idle and flawless run. When hot, first the bike began to run rough, besides worse and worse until she was stopped. So, I used to make her cool and the bike started again. Good work Ciao |
| Author: | dmartis [ Tue Feb 19, 2013 12:16 am ] |
hey mate so in your case it was the flywheel pickup sensor ? correct. that is the devise with a sensor at one end which slots into the left engine side cover, joined by a flexi cable to a square two pin plug, that connects to the digiplex unit. . i have orded one local so we will give it a shot. fingers crossed
| Author: | persempre907 [ Tue Feb 19, 2013 7:10 am ] |
Yes, in my case it was the flywheel pickup sensor, that one on the left side cover of the engine But, before to buy it, I would try to check it measuring its impendance. Somewhere here you'll find the right value. Now, I can't remember. Ciao |
| Author: | dmartis [ Tue Feb 19, 2013 7:28 am ] |
Thanks again for your help and wisdom. . the revolution will not be televised ha ha .
| Author: | paso750 [ Tue Feb 19, 2013 9:28 am ] |
according to the 888 workshop manual you should read 680 ohms +/- 15% at 20°C/68°F. The same pickup was used on: Ducati 851 `90 SP Ducati 851 `91-`92 Ducati 888 Superbike `92 Ducati 888 `93-> Ducati 900 SS `90 Ducati 906 Paso `88 Ducati 907 I.E. `92 Ducati 916 `94 Ducati 916 Monop.-Senna `95- Ducati 916 SP `96 just in case viewtopic.php?f=3&t=2938 |
