| Ignitech for 906? http://ducatipaso.org/forum/viewtopic.php?f=2&t=5921 |
| Author: | koko64 [ Fri Mar 29, 2013 9:54 am ] |
| Post subject: | Ignitech for 906? |
Is there an Ignitech available to replace the Digiplex in case of unrepairable failure? Would one have to fit Kokusan type ignition pick ups and flywheel, or would it be plug and play? |
| Author: | ducbertus [ Fri Mar 29, 2013 6:21 pm ] |
| Post subject: | Re: Ignitech for 906? |
Hi Koke, maybe not ignitech, but maybe these guys: http://www.carmoelectronics.com.au/inde ... grnvhlpdl2 Bertus |
| Author: | koko64 [ Fri Mar 29, 2013 10:31 pm ] |
Cool. Thanks |
| Author: | stigonpaso [ Thu Apr 18, 2013 8:28 am ] |
I emailed Ignitch asking that very question and this was their reply: Hello There are two possibilities : 1) unit TCI (unprogrammable). 2) unit TCIP4 standard (programmable). Both our unit do not contains sensor of inlet pressure (original unit it contains inside). But we think that this is possible run our unit on this bike without this sensor. We made this many times. Unfortunately we have not original connector. You have cut original connector and to use another connector delivered with our unit. What is your country ? Regards. IGNITECH |
| Author: | dave906 [ Mon Apr 29, 2013 11:21 am ] |
Another one to try is Silent-Hektik in Germany. Haven't used the product myself but it seems to be a plug in replacement and they also offer coils and leads claiming improved performance over the standard items. You can use google translate to get more info from their mainly German web site. They were quite responsive when I enquired in more detail some years ago. http://www.silent-hektik.com/Duc_Digi.htm http://www.silent-hektik.com/PB_DP_08.pdf |
| Author: | koko64 [ Thu May 02, 2013 7:22 am ] |
Thanks. I like the Ignitech. Set your own map for high compression pistons and fuel availability. Cool. The water cooled 906 seems a good candidate for a high comp/big bore kit. |
