| coil mounting http://ducatipaso.org/forum/viewtopic.php?f=2&t=5977 |
| Author: | badhabrace [ Sat Apr 20, 2013 2:48 pm ] |
| Post subject: | coil mounting |
Hello everyone, I am back at it again, trying to make my Paso more reliable and failing miserably I was taking off the rear cylinder coil to clean the ground and the one bolt snapped on its way out. I drilled and tried the trusted easy out,which snapped. I tried drilling the easy out,with no luck. Where are you fellow Paso owners mounting the coil at where you get a good ground with little effort? (ie-drilling into frame? Thanks a ton and keep the rubber side down! Rich |
| Author: | higgy [ Sun Apr 21, 2013 12:38 am ] |
| Post subject: | Re: coil mounting |
you need a product caller rescuebit,made for drilling out broken taps and extrators here in the US a 1/8 double ended Rescuebit goes for about 40USD but it will drill into the broken extractor and allow you to ream out the rest |
| Author: | Mc tool [ Sun Apr 21, 2013 9:56 am ] |
