ducatipaso.org :: View topic - Sat Nav
ducatipaso.org
http://ducatipaso.org/forum/
Sat Nav
http://ducatipaso.org/forum/viewtopic.php?f=2&t=6224
Author:  Giscard [ Tue Jun 18, 2013 8:46 am ]
Post subject:  Sat Nav
Has anyone successfully fitted a Sat Nav to a Paso. If so how did you mount it and was there clearance from the screen ?
Author:  paso750 [ Tue Jun 18, 2013 4:27 pm ]
Post subject:  Re: Sat Nav
if you have a magnetic map holder or a tankbag with a clear top you can put it in there but I guess that`s not the asnwer you wanted ;)
Author:  englishstiv [ Tue Jun 18, 2013 4:45 pm ]
I use one of these...well similar at least with my Garmin car sat nav also works well with a Samsung S3 enclosed you will need the other parts listed lower down to fit or you can get them with a handle bar mount.
Mine is a bit of "Heath Robinson" affair copied from this.
http://www.amazon.co.uk/Universal-Water ... grid_i_0_2
My bike is in bits at the mo' but will try and rig it up and take a photo if I get time....there is room under the nacelle screen to fit a unit.
Author:  Giscard [ Tue Jun 18, 2013 6:25 pm ]
Thanks for the replies. Yes I was looking for something more secure than the magnetic fixing.
As regards the handlebar mount is there enough room on the Paso bars as the fluid reservoirs seem to get in the way ?
Author:  nnnnnnorman [ Tue Jun 18, 2013 7:36 pm ]
are you sure????????? :cool:
Author:  Giscard [ Tue Jun 18, 2013 8:20 pm ]
If you mean am I sure that the fluid reservoirs will get in the way of a handlebar mount - no I am not. I was suggesting that it looks very tight, unless someone knows better.
Author:  englishstiv [ Tue Jun 18, 2013 10:14 pm ]
Sorry I didn't mean mount them on the bars as this is not feasible unless you are very clever with some tinware to loop a bracket under the brake/clutch and switch gear and then use the mounting bracket to fix it onto the bike.
You can though use this if you fabricate a small bar and tie wrap it onto and over the rubber mount between the screen and above the top tree.
Author:  Giscard [ Wed Jun 19, 2013 7:38 am ]
Author:  Ducolaf [ Wed Jul 17, 2013 8:11 am ]
Hi all, fitted the Garmin Zumo 350 LM to my 907 i.e. this year.
I replaced one of the bolds holding the handle bar and front brake fluid reservoir to the top plate of the front fork by a RAM-mount bolt. On this I use the longer RAM connection device (10 cm) so I can move the Zumo to a position behind the screen and not block the instruments in the cockpit. As the steering turns the Zumo turns too, make sure it does not run into the front fairing.
Fit it close to your right hand for simple operation during driving (not preferred)
Works great for me, easy access, easy to install / remove and minimum modification. The black RAM-mout is hard to see with the black metal handlebars. Nice Allenbolt for replacement, labeled the original bolt and stored it away. Cost were low as well. Check out this site for an indication on product and price
Need more detailed close up? Please let me know and I will post some pics.
In this pic you just can see the side of the Zumo during a tank stop against the blue colomn.
File comment: Tankstop Germany filling the 907. Running 1 ltr on 20 km ;-)
qNh-TO0O1cLoMAJk8VmKhjggX_cttAWjBGVEao3xkZo,gSCAjls_I9mopOdTTWVXcT-rBifqyfyU6KOMwB05XwU.jpg
qNh-TO0O1cLoMAJk8VmKhjggX_cttAWjBGVEao3xkZo,gSCAjls_I9mopOdTTWVXcT-rBifqyfyU6KOMwB05XwU.jpg [ 144.12 KiB | Viewed 12906 times ]
Author:  Ducolaf [ Thu Jul 18, 2013 12:36 pm ]
Made some pics for you, they can all be found here:
This is how it looks
Author:  Giscard [ Wed Aug 21, 2013 10:32 am ]
Thanks Ducolaf - very helpful.
Author:  Duc750 [ Mon Sep 02, 2013 9:11 pm ]
if you want a really good looking permanent fix - but very expensive look at gadget guy.net
Author:  Ducolaf [ Wed Sep 11, 2013 1:19 pm ]
Don't like his products. Much too big, too heavy, too much in your face. Looks like a cowbar. . .
Well, tasts are different luckily, however thanks for the update as sure it is nice to share information here.
Page 1 of 1 All times are UTC
http://www.phpbb.com/
