| Fitting a RR51 Regulator/Rectifier to a 906 ? http://ducatipaso.org/forum/viewtopic.php?f=2&t=6379 |
| Author: | A 9ASO [ Wed Sep 18, 2013 2:51 pm ] |
| Post subject: | Fitting a RR51 Regulator/Rectifier to a 906 ? |
I know that there is a huge amount of knowledge out there with all you members and hope that some of you can help me out with this problem that I have. I have had charging problems and have bought a RR51 from ElectrexWorld but am confused as to how to connect it !! I assume that my bike has an alternator with 3 output cables (diagram2) BUT The original unit has 2x Yellow wires, 2x Red wires, 1x White wire and 1x Black wire. This connects into the loom by a block where both of the Yellow wires each become Pink; the first Red becomes a Red with Black line AND an Orange with a Red line; the second Red continues as a Red cable; the White becomes a Blue; and the Black becomes a Brown. I am affraid that I am very confused about this. I think that the 2 x Pink wires are from the alternator, together with the Red one? The Brown appears to be from a fuse and assume that this is replaced by the new Red to the battery ? The Blue, Red/Black and the Orange/Red appear to all lead to the instrument panel. Can anyone give me advice on these and what should be connected to which wire.???? Grateful for any advice Guys.
| Author: | higgy [ Wed Sep 18, 2013 3:47 pm ] |
| Post subject: | Re: Fitting a RR51 Regulator/Rectifier to a 906 ? |
First thing you need to do is check your stator for shorts or opens with an ohmmeter see this thread |
| Author: | paso750 [ Wed Sep 18, 2013 3:50 pm ] |
| Author: | A 9ASO [ Wed Sep 18, 2013 5:16 pm ] |
Thank you very much. This is just the information that I need. I assume that the Red/Black and the Orange wires are replaced by the RR51 Red and Green being connected directly to the battery terminals and can therefore be taped up or removed/disconnected? |
