ducatipaso.org • View topic - Grose Jets
It is currently Fri Oct 30, 2026 5:17 pm
 Post subject: Grose Jets
PostPosted: Thu Feb 26, 2015 8:14 am
Are the Grose jets no longer available for the Weber 44 DCNF. I have tried following up on contacts from this site but have failed miserably. I am based in the UK but accept that they will probably only be obtainable in the U.S. if at all.
 Post subject: Re: Grose Jets
PostPosted: Thu Feb 26, 2015 9:17 am
what size are they ?
I replaced all parts in my Weber a few years back and had no problem finding them all.
http://www.dellorto.co.uk/merchandise/p ... tionID=135
PostPosted: Thu Feb 26, 2015 11:47 am
From what I understand Mr Grose turned the biz over to his son a few years back and no one has heard from either of them since. You may still find one at antique carb shops in the UK and Canada
I believe they originally came from Stromburg back in the late 40's early 50's and had been "rediscovered by Mr Grose "in 1970
you may try D & G Valve Mfg. Co., Inc. on 8 Mt. Vernon Street,Stoneham, MA 02180
Phone (781) 438-1789
PostPosted: Thu Feb 26, 2015 5:17 pm
Thanks for the feedback.
Paso 750 the link you gave refers only to needle valves, which I have a couple of. I thought I would see of the Grose jet was any improvement over that.
Higgy I had already found the D & G Vale Mfg Co but apart from Arlen Grose being named I could not locate an email address or a website. I have my doubts that it will be of much use to me as it appears a small operation. I will just have to stick with the needle valve.
PostPosted: Thu Feb 26, 2015 8:37 pm
you can try here.
last time, when i talked with him, he told me that he can get weber parts
English is no problem
PostPosted: Tue Mar 03, 2015 2:37 pm
Hi ved. I emailed him but to date I have had no reply, which I take as product unavailable. Guess I will stick with the needle jet after all. Presumably the Grose jet was not universally accepted.
PostPosted: Thu Mar 05, 2015 8:10 pm
Users browsing this forum: No registered users and 28 guests
