It is currently Wed May 22, 2024 9:07 am
[ 7 posts ] |
Author |
Giscard
Post subject: Grose Jets Posted: Thu Feb 26, 2015 8:14 am |
Joined: Thu Apr 28, 2011 2:56 pm Posts: 120 Location: Cardiff UK and Dordogne France
Are the Grose jets no longer available for the Weber 44 DCNF. I have tried following up on contacts from this site but have failed miserably. I am based in the UK but accept that they will probably only be obtainable in the U.S. if at all.
Top |
Post subject: Re: Grose Jets Posted: Thu Feb 26, 2015 11:47 am |
paso grand pooh-bah |
From what I understand Mr Grose turned the biz over to his son a few years back and no one has heard from either of them since. You may still find one at antique carb shops in the UK and Canada
I believe they originally came from Stromburg back in the late 40's early 50's and had been "rediscovered by Mr Grose "in 1970
you may try D & G Valve Mfg. Co., Inc. on 8 Mt. Vernon Street,Stoneham, MA 02180 Phone (781) 438-1789
Top |
Giscard
Post subject: Re: Grose Jets Posted: Thu Feb 26, 2015 5:17 pm |
Thanks for the feedback. Paso 750 the link you gave refers only to needle valves, which I have a couple of. I thought I would see of the Grose jet was any improvement over that. Higgy I had already found the D & G Vale Mfg Co but apart from Arlen Grose being named I could not locate an email address or a website. I have my doubts that it will be of much use to me as it appears a small operation. I will just have to stick with the needle valve.
Top |
ved
Post subject: Re: Grose Jets Posted: Thu Feb 26, 2015 8:37 pm |
Joined: Fri Aug 13, 2004 12:00 am Posts: 48 Location: South Germany
you can try here. last time, when i talked with him, he told me that he can get weber parts English is no problem
Top |
Giscard
Post subject: Re: Grose Jets Posted: Tue Mar 03, 2015 2:37 pm |
Hi ved. I emailed him but to date I have had no reply, which I take as product unavailable. Guess I will stick with the needle jet after all. Presumably the Grose jet was not universally accepted.
Top |
smartino67
Post subject: Re: Grose Jets Posted: Thu Mar 05, 2015 8:10 pm |
Joined: Thu Mar 05, 2015 2:05 pm Posts: 6 Location: Italy
Top |
[ 7 posts ] |
Users browsing this forum: No registered users and 1 guest |
