It is currently Wed Feb 25, 2026 9:13 am
[ 6 posts ] |
| Author |
FasYankee
Post subject: 906/907 brake line compatibility question. Posted: Fri Nov 13, 2015 6:25 am |
Joined: Fri Jun 12, 2015 8:21 pm Posts: 28 Location: USA
Hey guys, quick question: I've decided to start compiling parts needed for the resto/refresh of my 906 Paso. In shopping for braided brake lines I spotted a set on flea-bay that are listed for '87-'90 Paso 750. Are these compatible with the '90 906? I'd figure that they can't be too much different if at all, seeing that the bikes are similar & manufacturers usually use like parts for same year machines, but I wanted to seek experienced opinions. Another issue is finding rebuild kits for the calipers.....any ideas on where to search?
Thanks in advance!
| Top |
Giscard
Post subject: Re: 906/907 brake line compatibility question. Posted: Thu Nov 19, 2015 9:23 am |
Joined: Thu Apr 28, 2011 2:56 pm Posts: 120 Location: Cardiff UK and Dordogne France
Bevel Heaven seem to have a lot of the bits for refurbishing callipers and master cylinders. Be cautious with brake and clutch lines as I bought a set from a company on ebay and could not get them to stop leaking at the line splitter on the front brake using the oem set up.
| Top |
FasYankee
Post subject: Re: 906/907 brake line compatibility question. Posted: Sun Nov 22, 2015 7:44 am |
I was planning on going with a 2 line setup from the M/C and ditching the splitter altogether.
| Top |
Post subject: Re: 906/907 brake line compatibility question. Posted: Sun Nov 22, 2015 11:01 am |
| paso grand pooh-bah |
the answer is yes. If you look at the parts catalogues you see that the part numbers of the brake lines for the P750/906 and 750S are the same. The lines of the 907ie are different.
| Top |
Post subject: Re: 906/907 brake line compatibility question. Posted: Sun Nov 22, 2015 12:17 pm |
you'll need a micro switch for the brake light if you ditch the splitter Again Bevel Heaven to the rescue
I used a kit from these guys
Chris was very helpful.
Also any local hydraulic shop can make you a nice set of Teflon lines in almost any color you can think of.
| Top |
FasYankee
Post subject: Re: 906/907 brake line compatibility question. Posted: Tue Dec 01, 2015 6:04 pm |
Thanks for the replies! Yeah I'm going with the 2 line setup and a banjo switch. I've used them with good results on my supermoto conversion.
| Top |
[ 6 posts ] |
Users browsing this forum: No registered users and 5 guests |
