Fuel pump http://ducatipaso.org/forum/viewtopic.php?f=2&t=743 |
Author: | Beilby [ Wed Nov 09, 2005 6:10 am ] |
Post subject: | Fuel pump |
Hi folks. My fuel pump died and my mechanic tells me Ducati make them no more. Can anybody tell me where I can find an equivilant pump? It has been temporarily set up with just gravity feed for now (it is my only transport) but my mechanic tells me I will need to keep the tank over half full. It still runs the weber, by the way. |
Author: | redpaso [ Mon Nov 14, 2005 2:57 am ] |
Post subject: | |
Author: | JWilliam [ Fri Nov 18, 2005 5:19 pm ] |
I think you have two options. 1 visit your local Weber carbureter specialist with the fuel pump and quote the carb type (44DCNF). they should be able to match a new fuel pump. But don't get an injection pump. 2 take the pump apart and rewind the motor windings with equivalent transformer wire. Finally you could berate Ducati to drop their Motogp project and that silly V4 so that they can do a refit run for the Paso series. |
Author: | Beilby [ Mon Nov 21, 2005 4:21 am ] |
Post subject: | |
Bwahahaha - Magic suggestion RM. And thanks for the Gowanloch idea Red. |
Author: | jomo [ Mon Nov 21, 2005 11:24 am ] |
Post subject: | |
Author: | badhabrace [ Thu Nov 24, 2005 1:26 am ] |
Post subject: | |
Hi All! I had a pump failure on my 906 as well.....after a quick trip to my local Pep Boys, I fetched a Purolator universal fuel pump that is rated 3-5 psi. I think it was 36 bucks and has been working quite well! Good luck! |
Author: | tofffa [ Fri Nov 25, 2005 6:36 pm ] |
Post subject: | fuel pump |
i live in italy.here u can find quite every spare parts about ducati.if u seek for ducati dealers on web,u can get what u need...if u need i can give u some web adress. Andrea. |
Author: | pasomio [ Fri Dec 02, 2005 6:10 pm ] |
Post subject: | |
Author: | Beilby [ Sat Dec 03, 2005 9:43 am ] |
Post subject: | |
Author: | richardwajer [ Tue Apr 04, 2006 10:50 am ] |
Post subject: | |
I made a vacuum pump from a Monster fit. It works... but whit a lot of starting problems after few days not using. Also if the bike was driven at slow speed in the city, the petrol did not go through the pump.... Wise lesson: do not trie... :funny: After 3000kms I bought an old rusty pump from a scooter, never has been better before... Richard |
Author: | Gwenadu [ Tue Apr 04, 2006 9:56 pm ] |
Post subject: | |
I have also tested the Monster vacuum pump. After a week without running gas evaporated from the carbs. when the carbs were filled ![]() ![]() Alain. |
