| Clutch master cylinder http://ducatipaso.org/forum/viewtopic.php?f=2&t=7566 |
| Author: | ducatipete [ Thu Nov 10, 2016 9:20 am ] |
| Post subject: | Clutch master cylinder |
Need to over haul my master cylinder, assume its a Brembo, what diameter is the bore/any part numbers? many thanks Pete |
| Author: | Derek [ Thu Nov 10, 2016 9:41 am ] |
| Post subject: | Re: Clutch master cylinder |
I'm pretty sure you need a PS13 seal kit but it may be a PS12. Both are available from Gutsibits |
| Author: | paso750 [ Thu Nov 10, 2016 4:45 pm ] |
have a look at the bottom side of the pump. There should be a number stamped on the housing. |
| Author: | ducatipete [ Fri Nov 11, 2016 8:30 pm ] |
thanks, will have a look weekend... |
