ducatipaso.org • View topic - Cyliner Head Markings, what do they mean?
It is currently Thu Oct 29, 2026 8:20 am
 Post subject: Cyliner Head Markings, what do they mean?
PostPosted: Sun Jan 08, 2017 6:28 pm
Hi There. Just stripping down one of my Paso's and have noticed two things about the motor. 1, it has not got an engine number which I am assuming is because the crank case must have been changed ?? 2. there are markings on the cylinder heads of HU. See picture. Anyone know what the significance of these are? Feedback appreciated.
Paso 750 Yellow in bits
Paso 750 Red x 2 (one running)
Paso 906 in bits.
It is a habit I cant seem to give up!
 Post subject: Re: Cyliner Head Markings, what do they mean?
PostPosted: Tue Jan 17, 2017 5:48 pm
What's HU?
What picture?
I'm assuming 'timing marks for belt change' is the answer to your question, if you mean these.
Re the engine number - viewtopic.php?f=13&t=4088
Whereabouts in the UK are you?
2004 ST4S
2001 ST4
1987 Paso 750
PostPosted: Wed Jan 18, 2017 1:55 am
My SS had V2 on them , cant remember what Paso has but HU sounds familiar , I think they are just model ( of the head ) codes , like W heads have a hemi chamber , V's have the bathtub shape , other changes were for bronze or cast iron valve guide , removable clip on later models allowed the opener rockers to be slid aside ( as opposed to being removed completely ) to allow access to the closing shims.
PostPosted: Wed Jan 18, 2017 9:18 am
They means just what McTool says. They refer to the particular head design and components. The heads on my 907 are marked HZ. The 900SS I used to have had V2 which was desirable, unlike the W2 on some 900 Monsters which had smaller 750 sized inlet valves.
PostPosted: Wed Jan 18, 2017 3:18 pm
Ah I'm with it now, I thought 'HU was short for 'Horizontal something or other'. Wake up time I guess . . . :O
2004 ST4S
2001 ST4
1987 Paso 750
PostPosted: Wed Jan 18, 2017 6:57 pm
Yeah me too Mark , I actually ( in a moment of unbridled optimism) thought that maybe my V2 heads had been fettled by Brook Henry of Vee Two fame .............but no :-(
