ducatipaso.org
http://ducatipaso.org/forum/
906 piston orientation
http://ducatipaso.org/forum/viewtopic.php?f=2&t=7683
Author:  bigdjag [ Fri Mar 17, 2017 3:32 pm ]
Post subject:  906 piston orientation
Could someone please tell me the correct orientation for the pistons as I removed mine and forgot to mark which side points forward doh!
I did mark them horizontal and vertical though
Thanks :oops:
Author:  odd duc [ Fri Mar 17, 2017 5:53 pm ]
Post subject:  Re: 906 piston orientation
don't sweat it, I'm pretty sure they are symmetrical or at least close enough that there is no noticeable difference. I just put new pistons in mine and the new ones are symmetrical though I didn't measure the old ones. I'll put some calipers on the originals when i get home tonight.
Author:  paso750 [ Fri Mar 17, 2017 6:36 pm ]
clean the piston crown and see if there are markings. If there is an A and S near the valve pockets A is the intake, S the exhaust side.
The intake valve is bigger than the exhaust valve hence the different size pockets.
Author:  odd duc [ Fri Mar 17, 2017 7:14 pm ]
Yup, Just as I walked away from the computer it dawned on me that the pistons are clearenced for the valves. A lesson in thinking before I speak.
Author:  bigdjag [ Fri Mar 17, 2017 7:40 pm ]
Thanks for the reply guys
I downloaded the manual but it doesn't mention anything about it
Thanks again
Page 1 of 1 All times are UTC
http://www.phpbb.com/
