ducatipaso.org :: View topic - Rear brake pump
ducatipaso.org
http://ducatipaso.org/forum/
Rear brake pump
http://ducatipaso.org/forum/viewtopic.php?f=2&t=7909
Author:  Mirinn [ Sat May 05, 2018 2:26 pm ]
Post subject:  Rear brake pump
Hi, can you tell me which rear brake pump would fit the 906 Paso?
I wanted to rebuild only the piston, but I have not got anywhere in the EU, I will probably have to replace the whole brake pump
Author:  Derek [ Sun May 06, 2018 8:31 am ]
Post subject:  Re: Rear brake pump
Brembo seals and repair kits can be bought from KTM dealerships. Make sure that the model has the same master cylinder.
Author:  Mirinn [ Wed May 09, 2018 2:08 pm ]
my piston is 11mm and they do not have a supply
Author:  paso750 [ Fri May 11, 2018 10:59 am ]
you can still find the complete pump.
https://www.stein-dinse.biz/Brembo/Fuss ... rettyPhoto
Author:  Mirinn [ Tue May 15, 2018 1:48 pm ]
it will be it, thank you :thumbup:
Author:  Derek [ Wed May 30, 2018 10:53 am ]
For information. Repair kits for the Brembo PS11 rear master cylinder (and many more) are available from Gutsibits in the UK.
Author:  Mirinn [ Tue Jun 05, 2018 12:52 pm ]
I ordered here, thank you for the tip
https://www.stein-dinse.biz/Ducati/Brem ... 16254.html
I have a mounted brake and it works as it should :)
Page 1 of 1 All times are UTC
http://www.phpbb.com/
