It is currently Tue Oct 27, 2026 8:02 am
[ 7 posts ] |
| Author |
Jorian
Post subject: Rear sprocket mounting dimensions? Posted: Sat Nov 02, 2019 9:23 am |
Joined: Wed Sep 25, 2019 6:37 am Posts: 24 Location: Australia
Can someone kindly confirm the inside diameter size of the rear sprocket? It's a 1989 model 906.
Also, the owner's manual says it has 41 teeth, but the parts book says 40. Is there a well accepted preference?
Thanks, Jorian
| Top |
Derek
Post subject: Re: Rear sprocket mounting dimensions? Posted: Sat Nov 02, 2019 11:15 am |
| paso grand pooh-bah |
90mm according to JT sprockets :
| Top |
Post subject: Re: Rear sprocket mounting dimensions? Posted: Sat Nov 02, 2019 5:55 pm |
These bikes are fairly tall geared and mine , at 100kph in 6th gear is stumbling along at to low revs,sometimes I used 5th gear. So maybe try the 41
| Top |
Jorian
Post subject: Re: Rear sprocket mounting dimensions? Posted: Sat Nov 02, 2019 10:44 pm |
The one here has ID = 92mm, but it is evidently changed to suit an adaptor for use with a wide tyre which is no longer to be used. The sprocket carrier is also modified unfortunately, down to 88mm. Does anyone have a spare carrier they want to sell? Otherwise I'll have to restore this one, which I'd rather not.
Good also to have info on the ratios, so Thanks Folks.
| Top |
Post subject: Re: Rear sprocket mounting dimensions? Posted: Sat Nov 02, 2019 11:57 pm |
You could get a ring turned up , to fit between sprocket and carrier .....if you did it right you could use a larger/modified washers under the sprocket nuts to hold it in place
| Top |
Jorian
Post subject: Re: Rear sprocket mounting dimensions? Posted: Wed Nov 06, 2019 9:41 pm |
I found what I hope is the correct sprocket carrier, and bought it via ebay. It was not described as being fit for a Paso, but looks identical to the one here (modified).
| Top |
Jorian
Post subject: Re: Rear sprocket mounting dimensions? Posted: Thu Dec 12, 2019 6:00 am |
The received sprocket carrier is an assembly - light metal casting plus steel sleeve, spacers, bearings etc. The casting looks to be identical, and it's the internal parts that differ. Need to swap them for the Paso bits. I looked at some drawings of the bevel 900SS assembly, looks like I need to do some press work. Anyone done this, have any tips or warnings?
| Top |
[ 7 posts ] |
Users browsing this forum: No registered users and 3 guests |
