ducatipaso.org • View topic - Rear sprocket mounting dimensions?
It is currently Thu Oct 29, 2026 8:20 am
 Post subject: Rear sprocket mounting dimensions?
PostPosted: Sat Nov 02, 2019 9:23 am
Can someone kindly confirm the inside diameter size of the rear sprocket?
It's a 1989 model 906.
Also, the owner's manual says it has 41 teeth, but the parts book says 40.
Is there a well accepted preference?
Thanks,
Jorian
 Post subject: Re: Rear sprocket mounting dimensions?
PostPosted: Sat Nov 02, 2019 11:15 am
90mm according to JT sprockets :
PostPosted: Sat Nov 02, 2019 5:55 pm
These bikes are fairly tall geared and mine , at 100kph in 6th gear is stumbling along at to low revs,sometimes I used 5th gear. So maybe try the 41
PostPosted: Sat Nov 02, 2019 10:44 pm
The one here has ID = 92mm, but it is evidently changed to suit an adaptor for use with a wide tyre which is no longer to be used.
The sprocket carrier is also modified unfortunately, down to 88mm.
Does anyone have a spare carrier they want to sell?
Otherwise I'll have to restore this one, which I'd rather not.
Good also to have info on the ratios, so Thanks Folks.
PostPosted: Sat Nov 02, 2019 11:57 pm
You could get a ring turned up , to fit between sprocket and carrier .....if you did it right you could use a larger/modified washers under the sprocket nuts to hold it in place
PostPosted: Wed Nov 06, 2019 9:41 pm
I found what I hope is the correct sprocket carrier, and bought it via ebay.
It was not described as being fit for a Paso, but looks identical to the one here (modified).
PostPosted: Thu Dec 12, 2019 6:00 am
The received sprocket carrier is an assembly - light metal casting plus steel sleeve, spacers, bearings etc.
The casting looks to be identical, and it's the internal parts that differ. Need to swap them for the Paso bits.
I looked at some drawings of the bevel 900SS assembly, looks like I need to do some press work.
Anyone done this, have any tips or warnings?
