ducatipaso.org :: View topic - Sprocket cover interchangeable?
ducatipaso.org
http://ducatipaso.org/forum/
http://ducatipaso.org/forum/viewtopic.php?f=2&t=8183
Author:  Jorian [ Tue Oct 01, 2019 1:55 am ]
Post subject:  Sprocket cover interchangeable?
750 and 906 Pasos have different part numbers for this part.
But can one from a 750 fit a 906, or is there an important difference?
Author:  Mc tool [ Tue Oct 01, 2019 10:59 pm ]
Post subject:  Re: Sprocket cover interchangeable?
Some times the quickest way to find out is to go to good ole eBay ( or elsewhere ) and see if you can't view pix of parts for sale. I thing the 750 and the 906 motor are based on different crankcases so it probly is different
Author:  Derek [ Wed Oct 02, 2019 8:45 am ]
The cover on the 500 and 600 Pantah engines are certainly different. I'd assume that the 750 Paso engine which is based on the Pantah engine is also different.
Author:  paso750 [ Wed Oct 02, 2019 4:34 pm ]
Author:  Jorian [ Sun Oct 06, 2019 9:02 am ]
The Paso 906 here has the clutch slave cylinder on the right.
So, a Paso 750 sprocket cover should be OK.
Thank you for the info.
Author:  Duc906 [ Tue Oct 08, 2019 11:19 am ]
Author:  paso750 [ Tue Oct 08, 2019 3:58 pm ]
Ken, you're right. My bad.
Author:  Jorian [ Thu Dec 12, 2019 6:07 am ]
The sprocket cover was described as fitting Paso 750 and 906.
It fits perfectly, with a cutout for the dummy clutch slave cylinder.
Page 1 of 1 All times are UTC
http://www.phpbb.com/
