| Rear sprocket mounting dimensions? http://ducatipaso.org/forum/viewtopic.php?f=2&t=8201 |
| Author: | Jorian [ Sat Nov 02, 2019 9:23 am ] |
| Post subject: | Rear sprocket mounting dimensions? |
Can someone kindly confirm the inside diameter size of the rear sprocket? It's a 1989 model 906. Also, the owner's manual says it has 41 teeth, but the parts book says 40. Is there a well accepted preference? Thanks, Jorian |
| Author: | Derek [ Sat Nov 02, 2019 11:15 am ] |
| Post subject: | Re: Rear sprocket mounting dimensions? |
90mm according to JT sprockets : |
| Author: | Mc tool [ Sat Nov 02, 2019 5:55 pm ] |
These bikes are fairly tall geared and mine , at 100kph in 6th gear is stumbling along at to low revs,sometimes I used 5th gear. So maybe try the 41 |
| Author: | Jorian [ Sat Nov 02, 2019 10:44 pm ] |
The one here has ID = 92mm, but it is evidently changed to suit an adaptor for use with a wide tyre which is no longer to be used. The sprocket carrier is also modified unfortunately, down to 88mm. Does anyone have a spare carrier they want to sell? Otherwise I'll have to restore this one, which I'd rather not. Good also to have info on the ratios, so Thanks Folks. |
| Author: | Mc tool [ Sat Nov 02, 2019 11:57 pm ] |
You could get a ring turned up , to fit between sprocket and carrier .....if you did it right you could use a larger/modified washers under the sprocket nuts to hold it in place |
| Author: | Jorian [ Wed Nov 06, 2019 9:41 pm ] |
I found what I hope is the correct sprocket carrier, and bought it via ebay. It was not described as being fit for a Paso, but looks identical to the one here (modified). |
| Author: | Jorian [ Thu Dec 12, 2019 6:00 am ] |
The received sprocket carrier is an assembly - light metal casting plus steel sleeve, spacers, bearings etc. The casting looks to be identical, and it's the internal parts that differ. Need to swap them for the Paso bits. I looked at some drawings of the bevel 900SS assembly, looks like I need to do some press work. Anyone done this, have any tips or warnings? |
