| fuel gauge bounces http://ducatipaso.org/forum/viewtopic.php?f=2&t=8358 |
| Author: | yosemite [ Thu Jan 21, 2021 12:13 pm ] |
| Post subject: | fuel gauge bounces |
Hi was out on the 906 yesterday for a test ride and to get fuel, the only problem is the fuel gauge was fine when filled but after a while when fuel level started to drop the gauge started to bounce up and down quite rapidly. when I got back with the bike on its stand the gauge was steady but if I rocked it then the needle would bounce Is this normal or is there meant to be some sort of damping on the gauge. I was thinking of connecting a capacitor accross the gauge to smooth out the reading. Does any one have any thoughts? |
| Author: | Duc906 [ Fri Jan 22, 2021 3:32 am ] |
| Post subject: | Re: fuel gauge bounces |
I had the same issue with mine, when the fuel level got down to near half the needle on the gauge would bounce or drop to empty. The issue I found was with the fuel level sender it the tank. The wiper arm in the sender unit wasn't making contact with the coil in the middle. I just bent the wiper arm so that it made contact all the way across the coil and it fixed the problem. I wish I had taken some photos when I had it apart but I found this video that goes through a similar issue. |
