ducatipaso.org • View topic - 906 No idle
It is currently Sun Sep 28, 2025 11:26 pm
 Post subject: 906 No idle
PostPosted: Mon Apr 24, 2006 12:56 pm
Hello all Paso fans.
I own a 906 which was stored for 2 years, because I couldn't get new tires. Now I have some and I want to drive, but the engine doesn't start anymore. I checked the carb and noticed that it was dry, the floatneedle was sticky. Also the carb was contaminated so I cleaned the complete carb. Now the engine runs but not at idle only when I switch the choke at max. the engine idle at 1100revs.
When I set the choke at a warm engine (90°C) on min. the engine doesn't idle anymore. I checked the intake on false air and the throttle response is OK too.
Can one of you tell me how to adjust the Weber carb and/or were I get information about how this type of carb works?
PostPosted: Mon Apr 24, 2006 4:41 pm
:cool:
Click on 'Search' at the top of ther page, then type in 'weber' and you'll find lots of information.
PostPosted: Mon Apr 24, 2006 6:14 pm
Sounds like the idle jet is clogged up with junk or old fuel that has dried inside of it. To clean it you'll have to take it out and soak it in carb cleaner or run a small wire thru it and then blow it out with air.
PostPosted: Thu Apr 27, 2006 7:45 am
PostPosted: Sat Apr 29, 2006 7:09 pm
Seems, that you NEED clean totally Your carburator... Make notes, where is all Your adjustments and put it to pieces, clean and rebuild with Your notes about adjustments.... Maybe need new "gasket" set, what can be found from Ducati dealer.
 Post subject: Problem is solved
PostPosted: Mon May 08, 2006 9:27 am
