ducatipaso.org • View topic - temperature gauge
It is currently Fri Apr 24, 2026 10:39 pm
 Post subject: temperature gauge
PostPosted: Thu Feb 07, 2008 4:15 am
On my 1992 907ie what is the normal operating temperature the gauge should read when the bike is warmed up??It has no red zone and I cant find any info in the manuel regarding this.Thanks....glenn
 Post subject: Re: temperature gauge
PostPosted: Thu Feb 07, 2008 11:42 am
according to the manual the fan switches on at 92°C.
I`d say normal operating temp should be 60-80°C. (120-170°F), while the "red zone" starts at 120°C (250°F)
PostPosted: Thu Feb 07, 2008 6:11 pm
If you're asking because your temp gauge is very hight, you have to know the 907 always has the gauge quite hight, above all when you stop the bike, as at the traffic light.
In the summertime, or you always run, or your ass will go burnt :evil: :evil: :evil: .
PostPosted: Fri Feb 08, 2008 3:35 am
I'm an air cooled guy but is it reading water temp?? If so, shouldn't it read whatever the thermostat (one warm) is set for or above?
PostPosted: Fri Feb 08, 2008 12:18 pm
Jon, you`re right. ... water cooling. I didn`t think about that.
Considering this I would say normal temp is still as stated but red zone starts at 100°C.
PostPosted: Fri Feb 08, 2008 6:10 pm
PostPosted: Fri Feb 08, 2008 10:05 pm
Hi, my 907 runs the most of the time 70 degree celsius.
sometime a little bit lower, when the ambient tempereatures between 0 and 10.
Summertime, I never saw 90.
I know from a friend who has a motocross tuning store, he's aiming for 70 degree.
At this point the 2-stroke engine performs the best, and I don't why a 4-stroke should be differrent.
The max. temp can be above 100 as the system is slightly pressuraised.
ducbertus
PostPosted: Fri Feb 08, 2008 10:16 pm
ST2 have quite accurate temp meter and engine is very similar to 907 and ST2 meter shows in normal driving near hole time 73C.... :smoke:
PostPosted: Sat Feb 09, 2008 7:19 am
