It is currently Sun May 03, 2026 11:02 am
 Post subject: cooling system pressure
PostPosted: Fri Apr 10, 2009 7:14 am
I think I have successfully plastic welded my split coolant overflow tank.
I can't blow any air through leaks under water.
Does anyone know what the pressure in the cooling system is that the tank should be able to withstand?
Thanks,
SMS
 Post subject: Re: cooling system pressure
PostPosted: Fri Apr 10, 2009 7:22 am
I wouldn't tell any crap, but the 907's cooling system wouldn't be under pressure.
So, it's enough that it doesn't have any leak.
PostPosted: Sun Apr 12, 2009 7:10 am
the working pressure is marked on the water cap.
That should be 1.1 or 0.9 (this means 110% or 90% over the normal atmospherical pressure)
