ducatipaso.org • View topic - Mechanic Needed (Non-Nincompoop)
It is currently Tue Sep 30, 2025 2:36 pm
 Post subject: Mechanic Needed (Non-Nincompoop)
PostPosted: Sun Feb 13, 2011 10:21 pm
I live in Vancouver, BC. I see there are a few owners of 907's in the Lower Mainland. Does anybody know of a bike mechanic that is familiar with my bike (1991 907ie)? My mechanic moved away, and none of the dealers around here want to touch it. My main problem is a ridability issue, i.e. surging.
Goodonya,
Bonza
 Post subject: Re: Mechanic Needed (Non-Nincompoop)
PostPosted: Mon Feb 14, 2011 3:39 am
Search this site for the cigarette butt fix that really does work. Did mine, should be some pictures. Also if you balance the throttle bodies it will help. Another thing that will help is changing the chip to one with a richer map.
There are other things that will help. Guys on this site will have more information for you.
du907
PostPosted: Mon Feb 14, 2011 7:25 am
Nice wheelie Bonza!
PostPosted: Mon Feb 14, 2011 8:19 am
Cheers Claude.
'92 907...numero 2046
'92 851...in progress
PostPosted: Mon Feb 14, 2011 3:35 pm
Take a look here:
viewtopic.php?p=32528#p32528
PostPosted: Tue Feb 15, 2011 5:10 pm
PostPosted: Thu May 05, 2011 1:01 pm
the genius who thought of the ciggie butt damper should be honored...preferably with $$$ reward...and the occasional virgin sacrifice (you can have her back after)
viewtopic.php?f=3&t=2011&p=27784&hilit=ciggie#p27784
the wheelie is something the 907 will do if you have a flat spot at idle
I know these things...believe me...
at around 2,000 rpm a good throttle crack will get the front wheel skywards - you just need to be either stupid enough or unaware that the flat spot is happening to continue to hold the throttle open.
Soft-ish rear spring setting helps too..
at one stage I went 4 teeth larger on the rear sprocket - this was actually to change my top gear rev count at 100km/h (but that's another story) - the wheelies were dead easy with 10% more 1st gear power on tap and didn't require any clutch clanging dumps...
Laddie
CB750K7
CB500Four
CB250
CB175
DT175 Yam
PE250 Suzuki
PostPosted: Sun May 08, 2011 7:57 pm
Gidday Laddie
All this talk about clutch dumping and stuff does not have anything to do with it. That picture was taken on highway 35 in California and I was doing over 140k and you can see the hill in the background but I have no trouble doing wheelies doing in first gear and keeping it up all the way. The 907 has got loads of torque. Pretty good for a 20 year old bike!
Good on ya
Users browsing this forum: No registered users and 51 guests
