It is currently Sun Apr 26, 2026 9:19 pm
[ 6 posts ] |
| Author |
JoKing
Post subject: Which bearing type for swingarm? Posted: Sun Aug 28, 2011 8:37 am |
Joined: Mon Jun 20, 2005 12:00 am Posts: 362 Location: Northern Germany / Kiel
Hi guys,
i need the type/naming of all swingarm bearings & shaft seals. I do not want to buy them at ducati. They`d cost more than the swingarm itself.
Anyone knows?
Here the original part #s: 764000001 041202295 751632054 075549265 764000002
Cheers, Johannes
_________________ 92` Ducati 907 i.e. - ST3-Conversion --> Burned down with my barn 78` Ducati 900 SS - Bevel --> Sved her by risking my life 90` Cagiva Freccia C12R - Paso`s smaller sister --> Burned down with my barn 86` Ducati 750 Paso 96` Cagiva 750 AC Elefant
| Top |
JWilliam
Post subject: Re: Which bearing type for swingarm? Posted: Tue Sep 06, 2011 8:35 pm |
Joined: Wed Oct 06, 2004 12:00 am Posts: 327 Location: Nottingham, UK
I have only had to replace the bearing and seals for the shock linkage - 5 bearings total. The gearbox/frame pivot bearings were OK so I don't know the exact size for them (the right side is a double sealed type). If this is familiar then I can quote the linkage sizes.
_________________ http://www.youtube.com/watch?v=jf8Ic_aUWug
| Top |
pasolloyd
Post subject: Re: Which bearing type for swingarm? Posted: Thu Sep 15, 2011 11:55 pm |
Joined: Fri Dec 04, 2009 1:52 am Posts: 35 Location: Toronto
The numbers I retrieved from my swing arm are as follows: 075549265: 26mm x 20mm x 4mm seal 764000002: 260D 201D 18L bearing
Sorry I don't have the others...
Lloyd
_________________ '91 907ie '96 900 SS SP '97 900 SS CR (for sale) '74 750 GT (since new - sort of) '85 Pantah 600 (sold, but not forgotten)
| Top |
pasolloyd
Post subject: Re: Which bearing type for swingarm? Posted: Fri Sep 16, 2011 12:25 am |
Oops! The others were on the previous page! I can see also some were not part numbers but sizes for the bearings. Let's try again:
764000001: 32mm OD x 25mm ID x 18mm L needle bearing 041202295: 32mm x 25mm x 4mm seal 751632054: #630004 2RS1C3 075549265: 26mm x 20mm x 4mm seal 764000002: 26mm OD x 20mm ID x 18mm L needle bearing
Again, these were taken from my swingarm components
| Top |
JWilliam
Post subject: Re: Which bearing type for swingarm? Posted: Sun Sep 18, 2011 4:02 pm |
Aftermarket bearing sizes then : Mfr SKF Bearings Swingarm linkage bearings are 4 x HK2020 Needle bearing,1 x HK2030 Needle bearing and 6 x G20x26x4 Seal
Sprocket Carrier (always a good idea) 2 x 6005 2RS1
| Top |
[ 6 posts ] |
Users browsing this forum: No registered users and 14 guests |
