It is currently Fri Nov 14, 2025 5:57 am
Post new topic Reply to topic  [ 16 posts ]  Go to page Previous  1, 2
 Post subject: Re: Damn Banjo Bolts...
PostPosted: Wed Nov 23, 2011 3:31 pm
entire bolt
If I get the chance today I will check the clutch end of the 907 as well,just to be sure
I also have a cheap method of making a pressure bleeder at home I will present soon, those clutch systems can be a real hassle to bleed, reverse bleeding wint a pressure bleeder makes it a snap :thumbup: entire setup should be less than 30 usd not including fluid
